Volvo S70 blower motor issue
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
Hey guys,
I have a Volvo S70 from 1998 with an ECC. The main issue is with the blower. Sometimes it works, sometimes it doesn't. Today I removed the glovebox compartment and gave the connector on the blower motor a pull and it came back to life. Nudged a bit more and it stille kept on working. Cleaned the connector and the plug with some pc cleaner.
But, ofcourse, the blower motor didn't work when I drove to get some groceries. Can you guys help me out with some solid advice how to get rid of this problem?
Thanks in advance! :D
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
Brushes are close to end.
If my English is bad, please correct me :oops:
Ocelot
Post by Ocelot »
So I need a new blower motor?
Recent car
Has thanked: 1609 times
Been thanked: 4064 times
There is a good replacement motor from the company TYC that is about half the price of the Volvo OEM one.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Are there any codes stored in ecc?
Does ac and rec flash when there are codes stored like in 850?
Brushes are pretty durable on the volvo blowers.
Did you try to lube the shaft with some oil or wd40.
Power stage have high sensitivity and if blower pulls just a bit more voltage than it's suppose to pull,ecc will turn it off to protect circuits.
Lubing the bearings will solve the issue in 99.9%.
Talking from my personal experience.
Other thing you can do is to pull the fuse for ECC for 10min in order to reset ECC.
It should work after that....if not....you need to lube the bearings on the shaft.
You need to remove it in order to lube it.
Check the brushes while it's removed....brushes are replaceable part.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Take it out and lubricate with a few drops of engine oil.
- I wrote a DIY in forum...
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
Devils advocate here - wouldn’t lubing any part of fan cause dust to ‘stick’ to the oil/grease and only solve the issue short term?
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
misha
Post by misha »
Nope....you put a few drops on dry bearings with a straw and syringe down to the shaft.Dry bearings apsorb the oil,you wipe out the excess from the shaft.
Dust can't access the bearings.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
