V70 2004; As the title says, both right hand side turn signals flashes fast and illuminating weak, however left hand side is normal. I have searched all over for a possible solution and the location of the relay but with no luck. It would be greatly appreciated if someone could point me in the right direction....
Many thanks!
RHS turn signals flashes fast, LHS normal Topic is solved
- hanzbe420
- Year and Model: 2006 s60 2.5T
Your turn signal bulb is dead. When the signal blinks fast, that's the side it's on. So if your right rear blanket is out your right front blanket will blink faster cause of a surge and its getting more power I think. But change the bulb, its either upper right hand bulb or rear right hand bulb that is out. It should of said bulb failure on the dash.... I would check to see what lights do not light up and change the bad one.
- 629 Views
Last post by bmdubya1198
- 13 Replies
- 4964 Views
- 1154 Views
Last post by Rattnalle
- 3534 Views
Last post by jimzzr
- 676 Views
Last post by Calahonda52
