Did you know? 🤔
Coolant loss V50i 2005
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Bubbathegreat
Year and Model: 2005 V50
Has thanked: 4 times
Been thanked: 0
United States of America
Bubbathegreat
Post by Bubbathegreat » Sun Jan 19, 2020 12:47 pm
2005 V50i non turbo.
I'm new to Volvos. I loose about half a gallon of coolant every couple of weeks. and it is very intermittent. I cannot see where it is leaking from. it will only have a few drops around the engine and rest is on the underbody cover. (what's the proper name for that?) I have one hose that goes into the the firewall that is all bloated, but would it leak only sometimes? Any ideas as to how to find this leak? The oil level has not changed and is clean.
I read a post where coolant was leaking in the transmission.
viewtopic.php?t=47033 Could that be happening on my model?
Regardless I'm going to replace and the hoses just to be safe and at 165,00 miles. It needs to be done. True?
FCP Euro has a hose kit with the following: Is there anything else I should replace?
x 3 Engine Coolant / Antifreeze PEN-8114117 Pentosin logo $27.87
1 Engine Coolant Temperature Sensor FAE-33835 Fae logo $12.09
1 Engine Coolant Recovery Tank Hose VOL-30776162 Genuine volvo $20.22
1 Engine Coolant Recovery Tank Hose VOL-30680148 Genuine volvo $10.72
1 Engine Coolant Recovery Tank Hose VOL-30776155 Genuine volvo $20.22
X 1 Radiator Coolant Upper Hose CRP-CHR0350R Rein logo $17.72
X 1 Radiator Coolant Lower Hose CRP-CHR0386R Rein logo $14.44
X 1 Engine Coolant Recovery Tank VOL-30776151 Genuine volvo $61.48
X 1 Engine Coolant Recovery Tank Cap GAT-31549 Gates logo $7.14
x 1 Engine Coolant Thermostat VOL-31319606 Genuine volvo $84.30
Navservice
Year and Model: 2000 V40
Has thanked: 1 time
Navservice
Re: Coolant loss V50i 2005
Post by Navservice » Mon Jan 20, 2020 10:22 am
Hi, the hose going into the firewall is probably a heater hose. Do you have any signs of a leaking heater core? Stained carpet, foggy windshield, funny smell, or a general humid feeling?
These users thanked the author Navservice for the post:
Bubbathegreat
Bubbathegreat
Been thanked: 0
Bubbathegreat
Post by Bubbathegreat » Mon Jan 20, 2020 5:54 pm
Not in the cabin, just a slight smell when I open the hood, And an occasional 2x2 foot spot under the car. Maybe once a week.
Year and Model: 2001 V70
Has thanked: 2 times
Been thanked: 28 times
Post by volvolugnut » Mon Jan 20, 2020 6:18 pm
The underbody cover is called the splash pan.
The transmission fluid can be tested (Blackwell is one test company) for coolant and other contaminants. About $20 and you will also find out the transmission condition.
These coolant leaks typically only leak when the engine is running and the cooling system is pressurized. You may see some white dust staining at the point of leak. Trace all of the coolant lines including heater lines to firewall. If it makes a wet spot, there is a leak. Radiator necks and end tanks are known to crack over time.
Intermittent leak might be because of drive time and coolant temperature peaks. Higher temperature equals more pressure causes more leaking.
These users thanked the author volvolugnut for the post:
Bubbathegreat
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
