IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
99 V70 R rough idle after warm up and stalls
Has thanked: 12 times
Been thanked: 211 times
Canada
Re: 99 V70 R rough idle after warm up and stalls
Post by scot850 » Mon Feb 10, 2020 10:14 am
I would look at fuel pressure. It sounds like you are losing pressure and hence the engine dies. This can be tested at the Schreader valve on the fuel rail in the engine bay.
When was the fuel filter last changed?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
kklepack
Year and Model: 1999 V70R
Has thanked: 5 times
Been thanked: 2 times
United States of America
kklepack
Post by kklepack » Wed Feb 12, 2020 6:15 am
I checked the fuel pressure and when engine runs and by pressing the nipple on fuel rail fuel sprays strong, but when engine is off there is no pressure at all. Filter seems like has been replaced not too long ago. Filter looks new.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 318 times
Been thanked: 982 times
Trinidad & Tobago
Post by abscate » Wed Feb 12, 2020 6:47 am
An ME7 car (1999 on up) needs a solid 52 psi pressure and it should hold for 20 minutes after key off.
Check the pressure with a gauge - the squirt test isnt useful on these cars. Its common for the fuel system to fail and deliver marginal pressure, causing running problems.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
kklepack
kklepack
Post by kklepack » Fri Mar 06, 2020 5:13 pm
Little update: Car runs the same as before no improvement after changing below components and I still do not get any codes with VIDA.
I did compression test one more time and results are a lot better. Believe prevues gage was bad.
C1-155
C2-160
C3-160
C4-160
C5-160
New spark plugs NGK Spark Plug - NGK 6962
I did new PCV job with new blue box parts.
Replaced serpentine belt and idler.
Also replaced all vacuum lines with silicone ones and did cigar smoke test. I saw little smoke coming out of PTC nipple on the intake tube to the turbo. Also when I removed oil filler cap and dipstick smoke came out of there as well.
I did not find any other leaks anywhere else, but I hear hissing noise around by intake manifold by cylinder one where banjo bolt is and PCV (no coolant leaks)
Still have to do fuel pressure test. Went to rent fuel tester from AutoZone and it did not have right connectors.
Running out of ideas. I'm ready to take it to http://www.swedishcarspecialists.com/ and have them look at it.
Trinidad & Tobago
Post by abscate » Sat Mar 07, 2020 4:18 am
That air that is getting in there is not metered by the MAF, so the engine is not sending enough fuel to run, which will cause poor drive ability, especially at low rpm.
kklepack
kklepack
Post by kklepack » Sun Mar 08, 2020 9:50 am
Anything else you would suggest I look at ?
Trinidad & Tobago
Post by abscate » Sun Mar 08, 2020 12:28 pm
Fix that leaks so you get no smoke
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
TheOtherside
Post by TheOtherside » Sun Mar 08, 2020 8:37 pm
Same as my 98. Literally exact everything.
I just deal with it.
As for the milk on the oil cap, 100% because of moisture and short trips in the cold.
98 V70R
13 Flex w/EcoBoost
kklepack
kklepack
Post by kklepack » Mon Mar 09, 2020 6:34 am
So, you are just driving it that way? Never got it fixed?
TheOtherside
TheOtherside
Post by TheOtherside » Mon Mar 09, 2020 8:36 am
It always fires back up. Rough idle never lasts long. One week itll work flawless. Next week it stalls every 5 minutes.
Any time it stalls, I hold the key, itll turn over, fire up, immediately stall, (still holding key) itll turn back over, fire up and be good for however long it wants too.
Been driving it for 11 months now.
98 V70R
13 Flex w/EcoBoost
