98 V70 parts donation
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 318 times
Been thanked: 86 times
Post by CIK7 »
I've done this once before. I can't afford to spend much money on parts. I did receive some items which I didn't need, but may need later down the road. I did get important items: coolant bottle, then bought a PCV system.
Parts I need:
-Both turn signal housing
-complete (male/female) driver side turn signal light harness
-Trunk latch with striker plate
-grille with unbroken logo (would prefer classy type but egg crate works too
Parts I would like:
-N/A intake manifold
-N/A throttle body
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
hipcheck
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 7 times
Post by hipcheck »
Pretty sure I have the trunk latch. Will cross check the part number to make sure it matches
CIK7
Post by CIK7 »
hipcheck wrote: 21 Jan 2020, 07:37 Pretty sure I have the trunk latch. Will cross check the part number to make sure it matches
Sorry for a late response.
Thank you. I checked the one on my hatch and the part number wasn't visible. Are you able to put the striker plate (the steel catch) with the latch? I need this because my trunk-open light is on. I cut the rear lights out so the battery didn't drain. I have led strip lights (brighter 5050 type) to rewire the rear light wiring with.
