Trans leak through AWD Collar
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
A few months ago, I replaced my AWD collar and both of the RH transmission seals due to a leaking RH axle output seal. Now I am leaking there again, it has been a slow leak, and lately, we have had a real cold snap for 2 weeks (-25C as a high), and the leak has really increased. I am wondering if its possible the leak is coming through the splines on the transmission and AWD collar? I see Volvo uses an o-ring to seal this, and the dealer says they never change it, so I didn't. I did use grease on the splines when I replaced it.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- Has thanked: 2200 times
Could be the o-ring was nicked on fitting or is defective. When a dealer says they never replace it, is that still holding true for a 20+ year old car?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Regardless of the source of fluid, it should not travel pass the seal, unless. The drive axle seals work best if made by Volvo or CORTECO. Did the seal seat properly?befarrer wrote: 22 Jan 2020, 05:57 A few months ago, I replaced my AWD collar and both of the RH transmission seals due to a leaking RH axle output seal. Now I am leaking there again, it has been a slow leak, and lately, we have had a real cold snap for 2 weeks (-25C as a high), and the leak has really increased. I am wondering if its possible the leak is coming through the splines on the transmission and AWD collar? I see Volvo uses an o-ring to seal this, and the dealer says they never change it, so I didn't. I did use grease on the splines when I replaced it.
- befarrer
Seals were Volvo, they didvseat properly. Original leak was from the axle seal, looks to have been damaged from installing the axle. I made sure not to do that.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
xHeart
Either the seal was reversed/flipped when installing OR system way overfilled, else...befarrer wrote: 22 Jan 2020, 12:25 Seals were Volvo, they didvseat properly. Original leak was from the axle seal, looks to have been damaged from installing the axle. I made sure not to do that.
what seals?
- 454 Views
Last post by precopster
- 587 Views
Last post by E Showell
- 4313 Views
Last post by darrylrobert
- 632 Views
- 1282 Views
