Did you know? 🤔
XC90 Milerage
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
papoutsisy
Year and Model: xc90 2004
Has thanked: 0
Been thanked: 0
Greece
papoutsisy
XC90 Milerage
Post by papoutsisy » Wed Jan 22, 2020 9:49 am
Dear all,
i have an Volvo xc90 T6 2004
city driving i got a 18L/100km until 22L/100km
no DTC
is there any test to make to find the problem?
to check tyransmision and turbos etc etc?
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 4 times
Been thanked: 31 times
United States of America
wanderdüne
Re: XC90 Milerage
Post by wanderdüne » Wed Jan 22, 2020 3:59 pm
How is the air filter? You could start with changing that. http://www.skandix.de/en/spare-parts/fi ... r/1007248/
Part# 8638600
RickHaleParker
Has thanked: 3 times
Been thanked: 443 times
RickHaleParker
Re: XC90 Milerage
Post by RickHaleParker » Wed Jan 22, 2020 4:33 pm
Things the can decrease the fuel economy without tripping a DTC.
  • Degraded O2 sensors.
    Degraded Fuel Injectors.
    Clogged Air filters or poor grade.
    Tire pressure. ( Rolling friction ).
    Driving habits.
    Poor grade of motor oil can effect fuel economy by as much as 12%.
    ( More friction = more heat = more wasted energy )
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
papoutsisy
Has thanked: 0
Been thanked: 0
Greece
papoutsisy
Re: XC90 Milerage
Post by papoutsisy » Wed Jan 22, 2020 7:18 pm
thank you all for reply.
i have already change air filter before 5000km when i make service to the car.
my Driving is very very soft but it is city driving
tire presure are 35 psi (normal 32).
is there any way to check OS2 sensors before change
and i will go to check and clean Fuel injectors.
in the other way
is there any way to check turbos and automatic transmition .......?
RickHaleParker
RickHaleParker
Re: XC90 Milerage
Post by RickHaleParker » Wed Jan 22, 2020 10:08 pm
papoutsisy wrote: ↑
For degraded performance that does not produce a DTC ... no objective way.
Bosch recommends 100,000 miles preventive maintenance intervals for O2 sensors. If your O2 sensors have over 100,000 miles on them ... keep O2 sensors on the list.
If you do decide to replace the O2 sensors you will want the correct Bosch O2 sensors. Anything other may make the fuel economy worst. The three correct Bosch O2 sensors would put you back ~$375.00.
I would not blame you if you go through the rest of the list before you do the O2 sensors. However keep in mind with the 15 L/100 Km - 11 L/100 Km these trucks are rated for, it does not take a huge improvement in fuel economy to recover $375.00 in a reasonable amount of time.
Fuel injectors, remanufactured and flow matched Bosch 62672 / 0280155831 ~$75.00 - $100.00 for a set of six.
wanderdüne
wanderdüne
Re: XC90 Milerage
Post by wanderdüne » Wed Jan 22, 2020 10:53 pm
papoutsisy wrote: ↑
in the other way
Is there some reason that you suspect the turbos or transmission? I doubt that the transmission would affect the fuel economy, and if it were something wrong with the turbos, the car would run extremely poorly.
Does the XC90 roll easily when you let off the throttle? Can you verify if each wheel turns freely by jacking up each corner and spinning by hand with the transmission in N? After driving, can you sense if any wheel is hotter than the others? It's possible that there is a brake caliper sticking.
papoutsisy
Has thanked: 0
Been thanked: 0
Greece
papoutsisy
Re: XC90 Milerage
Post by papoutsisy » Fri Feb 07, 2020 6:53 am
Dear all.
After many changes and checks and ofcourse spend a lot of money for nothing....
The result is.
Cleaning throtle
Cleaning intake
Cleaning injectors
(But was clean)
Change all OS2 sensors with new bosh.
Change accelerator sensor pedal.
The consumption of the car still 21 liters per 100 km.
City driving and very smoth.
I dont understand other people have less consumption.
If some one have any sugestions please.
wanderdüne
wanderdüne
Re: XC90 Milerage
Post by wanderdüne » Fri Feb 07, 2020 8:01 pm
Do the wheels turn freely? For example, if you put the transmission in Reverse on flat ground, does it roll backwards without touching the gas pedal?
RickHaleParker
RickHaleParker
Re: XC90 Milerage
Post by RickHaleParker » Sat Feb 08, 2020 1:18 am
papoutsisy wrote: ↑
Cleaning injectors
(But was clean)
Did you just look at them or did you check the spray pattern and flow rate?
