2007 6-speed Transmission snake oil additive suggestions?
jerryv
Year and Model: 2007 XC90 3.2
Has thanked: 10 times
Been thanked: 3 times
Post by jerryv »
Im preparing my 2007 3.2L XC90 to tow a 1500-2000lb camper cross-country. I gave it the first and presumably only trans fluid flush at about 100k, now I'm at 125k.
There has been a rough 2-3rd gear shift since I got the vehicle and it seems to get worse with heat and hills. The flush seemed to smooth this out somewhat.
Anyone have good/bad experience with the "Lucas Transmission Fix", "Royal Purple", "Daryl's Supreme Liquid Transmission Mechanic" type additives for this type of Asin-Warner?
You think there's much sense in giving this "lifetime" fluid another flush before towing?
What's up with taking the car to a dealership to reprogram the shift patterns? Is this something I can do myself with my Chinese knockoff VIDA/DICE?
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
Which transmission fluid type and brand did you use and what method?
Don't reset the adaptive shift pattern.
jerryv
Post by jerryv »
It was Toyota Type T-IV I supplied, and I had a local indie shop do the deed, so not sure what their method was.
wanderdüne
How much fluid did you supply?
but anyway,
I'd replace the fluid again before I tried an additive. Here's a couple of links:
This is more complete:
http://www.timthurber.com/volvo-xc90-3- ... c-6-speed/
But this is the method I'd use; 2 or 3 fills and drains.
jerryv
Post by jerryv »
I think I supplied 14QT? It was all based on the above article/video/forum posts I've read. I think I'll do the drain+fill with another 12QT and throw in a little snake oil for good measure. Still soliciting suggestions for which brand!
wanderdüne
I'd go with lucas then, their other products seem to work well from what I've used.
