Just got a 2005 s60 and i noticed there is a gap on the top of the strut. Structs seem fairly new.
Could I just tighten the top bolt or were they installed wrong.
Car handles bumps fine.
Madness
Gap on strut
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
If you're referring to the gap between the top washer (with rubber feet on the bottom) to the top of the upper strut mount bearing, that's how Volvo designed it. It's suppose to be that way with somewhere around 1/4-1/3" gap there.
I once tried filling this with material cut from an old bump stop in the shape of a flat washer. Steering response improved somewhat at the expense of ride quality on smoother pavement. I decided I preferred the better ride quality over the minor improvement in steering response so I took it out.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Can you post some pics of the strut gap your referencing?volvomadness wrote: 22 Jan 2020, 22:16 Just got a 2005 s60 and i noticed there is a gap on the top of the strut. Structs seem fairly new.
Madness
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- June
- Has thanked: 523 times
- Been thanked: 261 times
shiloh51933 wrote: 23 Jan 2020, 07:53Can you post some pics of the strut gap your referencing?volvomadness wrote: 22 Jan 2020, 22:16 Just got a 2005 s60 and i noticed there is a gap on the top of the strut. Structs seem fairly new.
Madness
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
June’s gap looks about right.
A quick way to see if the spring seat is toast is to (with the hood open) try to bounce the front end of the car up and down. Watch the top hat washer & the gap underneath it. If it fluctuates significantly, the seat is probably done for. A more accurate way to see if your spring seat is shot (ie, inner bushing separated from vulcanized rubber) is to take the top plastic cap off, then remove the nut underneath. You may need to have a torx bit in the top of the shaft as a counterhold. Remove top “washer” & have a look. There is literally zero risk in doing this, so don’t be fearful.
This is an extreme, but will eventually happen if shot seats are left alone too long.
viewtopic.php?t=53566
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- shiloh51933
Thank you June, lol. I knew what OP meant I just wanted to see his actual strut but thank you.June wrote: 23 Jan 2020, 08:27shiloh51933 wrote: 23 Jan 2020, 07:53Can you post some pics of the strut gap your referencing?volvomadness wrote: 22 Jan 2020, 22:16 Just got a 2005 s60 and i noticed there is a gap on the top of the strut. Structs seem fairly new.
Madness
