Did you know? 🤔
Timing belt broke, head replacement?
melmaclifeform
Year and Model: 1999 S70 Base
Has thanked: 1 time
Been thanked: 0
United States of America
melmaclifeform
Re: Timing belt broke, head replacement?
Post by melmaclifeform » Fri Jan 24, 2020 5:27 am
Awesome!
As for making sure I have the right tutorial, I can be pretty certain that the tutorial from RobertDIY is adequate for my '99, correct? I know whiteblocks are similar so there are plenty of guides to go off of, but I would like to be certain.
Driver of the Pimpmobile, a $350 S70 with only 132k miles.
Has thanked: 274 times
Been thanked: 853 times
Trinidad & Tobago
Post by abscate » Fri Jan 24, 2020 6:41 am
Awesome!
I believe the 1999 is a hybrid
Solid cams, no VVT
Mechanical tensioner, not hydraulic like the -1998
So, that tutorial might not pick up on all the 1999 changes.
There is a thread on the 1999 changes in the 'Major Forum Topics' Sticky up top,
Sean in Boston was recently into his 1999 S70 NA for a head gasket - Ill link to his thread.
My favourite young guy is in Charlotte too, and despite his failings of youth Im sure he is one to mix up in with on Volvos.
(whew - almost dangled three prepositions)
Link To Volvo Glossary
melmaclifeform
Has thanked: 1 time
Been thanked: 0
melmaclifeform
Post by melmaclifeform » Fri Jan 24, 2020 6:50 am
A link to that thread would be great!
Trinidad & Tobago
Post by abscate » Fri Jan 24, 2020 7:11 am
melmaclifeform
Has thanked: 1 time
Been thanked: 0
melmaclifeform
Post by melmaclifeform » Sat Jan 25, 2020 5:10 pm
SuperHerman wrote:
Thu Jan 23, 2020 7:12 pm
You can source new valves for those bent or buy used ones. Pull the part number and see what other engines use it for used. The head is married to the cam cover - so don't go swapping.
What does it mean it's married to the cam cover? Wouldn't it be able to be swapped if it could be taken off? Or is that just an extra four hours of work?
SuperHerman
Has thanked: 0
Been thanked: 135 times
SuperHerman
Post by SuperHerman » Sat Jan 25, 2020 6:40 pm
No they are married meaning they are machined as a unit. The head and cam cover are to be viewed as one piece.
Year and Model: 2001 V70
Has thanked: 2 times
Been thanked: 28 times
Post by volvolugnut » Sat Jan 25, 2020 6:46 pm
What this means is Volvo factory selected a head and cam cover without the cam bearing bores, glued and bolted them together, and bored the cam bearing holes on both head and cam cover at the same time. This assured perfect alignment of head and cover cam bearings. Another cam cover will not have the cam bearings aligned for top and bottom surfaces.
This machining method assures great accuracy without the problems of using alignment pins while allowing the two surfaces to be separated for service.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
