Hello,
2006 XC90 v8. As the subject states the high beam headlights will not turn off unless the battery is disconnected or the fuses in the CEM are removed. These headlights are the normal lights not the self leveling xenon lights.
The low beams function normally and all the other functions of the dash/cluster work and are back lit appropriately. When pulling the stalk to activate the high beam lights the blue indicator light comes on the dash.
1) I replaced the high beam stalk and the problem continued.
2) I replaced the chip board module that the stalk plugs into in the column (module located under the clockspring/SAS) and the problem continued.
3) I disconnected the actual rotary light switch located to the left of the steering wheel and that was no help.
4) I disconnected the the ignition switch and several other modules located in the column and that was no help as well.
The only way to shut them off was pulling the fuses in the CEM (one fuse for each light D/P). To my understanding there is not a replaceable relay for the high beams in this vehicle which makes me wonder if the CEM is the problem?
Anyone think of something I missed checking?
Thank you
high beam headlights will not turn off unless battery is disconnected or fuses are pulled
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Off the top of my head it sounds like a sticking relay or the actual multi function lever switch itself(turn signal lever).black93gt wrote: 23 Jan 2020, 19:10 Hello,
Thank you
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- 1130 Views
Last post by racertim
- 1806 Views
Last post by IslandV70
- 783 Views
- 3277 Views
Last post by jimmy57
- 2686 Views
Last post by SuperHerman
