Door panel buttons not working
inktuce
Year and Model: 2001 C70
Has thanked: 2 times
Post by inktuce »
Hi everyone,
I have a 2001 Volvo C70 2.3L T5 and recently the door panel buttons (fuel door, trunk, and door locks) stopped working. The power windows still work, and I can lock/unlock my doors and open the trunk from the remote. The fuses are fine. Any ideas??
Thanks!
Has thanked: 2205 times
Been thanked: 1852 times
The panel on the door may have failed. On 4 door P80 chassis Volvos it is common at this age. The contacts burn out. Sometimes if you like a challenge, you can disassemble and try cleaning the contacts. I have had some success but it is not a 100%. I have not worked on a 2 door assembly but believe it would be similar.
The fact that the fob still works would suggest it is no broken wires in the door where it meets the A pillar. Last place to check would be the trunk cables on the trunk hinge assembly. Again the gas cap lid does not rout through there.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Go to the RH door and push and release the lock button on that side. It seems that a stuck button anywhere results in the VGLA module for locks and such on the 98-04 shuts down.
