Did you know? 🤔
Manual shifter binding when moving into neutral
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
askperry
Year and Model: S40 2006
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Sat Jan 25, 2020 7:15 pm
I have an issue with my manual shifter on my 2006 S40 T5.
When I move the shifter backwards from 1st gear, the shifter binds and requires some force to move it to the right, into neutral. Then is clunks into place.
When I move the shifter forwards from 2nd gear, the shifter binds and requires some force to move it to the right, into neutral. Then is clunks into place.
I have no problems moving the shifter any other direction.
Because of this when I try to shift from 2nd to 3rd it usually slips into 1st instead.
Reason: Edited title. Please, no "HELP"s in titles.
askperry
Has thanked: 0
Been thanked: 0
askperry
Re: Manual shifter binding when moving into neutral
Post by askperry » Tue Jan 28, 2020 5:52 pm
I disconnected the (left to right) shifter cable from the transmission and movd the selector lever on the transmission manually. The problem still happens (no shifter attached). So something is wrong in the transmission. The selector lever is attached to a cover plate. I'll open it and see if there is anything there that is easy to fix. Maybe I'll get lucky and find my long lost luck penny wedged in there. :p
askperry
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Sat Feb 01, 2020 10:19 am
Turns out the cover plate is an actually a module that slides out. I'm working on getting to it now. Has anyone ever removed one? Does it slide up and out?
askperry
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Sat Feb 01, 2020 2:08 pm
I've confirmed that the problem is in the Gear Selector module. I don't know what is causing the problem yet. The pin in the shift gate still won't move back to the neutral position unless it's bumped or hit. In the picture below, the pin is sitting on the side (bottom) of the shift gate when my hands off of the selectors on top.
askperry
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Tue Feb 04, 2020 7:01 pm
After beating, cleaning, fine-sanding and re-lubing every contact point I could find, I decided it was just time to buy a replacement. Just when I was about to put it down, I hard tapped the lateral shift lever, 3 times with a hammer, where it enters the top of the gear select module. That did the trick. The module works now.
I'll finish putting everything back together tomorrow and go for a test drive.
askperry
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Wed Feb 05, 2020 6:54 pm
Ok. I took it for a test drive for a few miles and no problems shifting at all. I'll get back with you all in a few days.
askperry
Has thanked: 0
Been thanked: 0
askperry
Post by askperry » Wed Jul 01, 2020 9:17 pm
It's been a few months and all is still fine.
