MVS-Amazon link helps MVS!
850 dash warning lights Topic is solved
crlande
Year and Model: 240DL;850;S70
Been thanked: 26 times
Post by crlande »
Ok board members, I got one for you... Hopped in my 850 this morning and started off to work. Less than mile and all the warning lights and headlights start to flicker. Turn around and hop in another car. This afternoon the car fires up, the air pump sounded muffled compared to the usual wind up, all warning lights are on, occasional flicker but all on. I jiggled some cables under hood, fiddled with the key while in ignition, turned on accessories, windows, headlights with nothing different. Car idles fine and starts each time. Did not check the diagnostics boxes under hood yet. Where the heck do I start diagnosing?
Thanks,
Carl
misha
Has thanked: 66 times
Been thanked: 176 times
Re: 850 dash warning lights
Post by misha »
Ignition switch or alternator.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 68 times
Been thanked: 42 times
Post by Cookeh »
I'm with misha on this one, you can test the ignition barrel/switch by jiggling the keys slightly with engine running and seeing if that temporarily fixes the problem.
crlande
Post by crlande »
Yes I thought the same. Tried jiggling the key in ignition several times, no difference.
misha
Post by misha »
Did you checked the alternator output voltage?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Post by crlande »
I have not checked the voltage output yet.
Thanks for your idea/ information.
crlande
Post by crlande »
Two days of doing nothing to car, the battery was 12.2 with engine off. Started car and battery was 11.5 while engine running. I am leaning towards alternator issue.
misha
Post by misha »
Check voltage output directly on alternator....on b+ and alternator housing.
We need this to determine if alternator is bad or battery cables are bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Post by crlande »
Today the battery was 12.2 before starting. The B+ and alternator housing was 11.45 as was the battery 11.45 while running.
misha
Post by misha »
Yep....alternator is shot.
Could be voltage regulator or the alternator itself.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
