850 dash warning lights Topic is solved
- misha
- Has thanked: 67 times
- Been thanked: 176 times
Re: 850 dash warning lights
If diodes are shot....the easiest solution would be a replacement(used) alternator.
BUT...usually....when diode(s) are shot,the battery warning light is always ON...even when the key is removed from ignition.
Do you have a battery warning light ON along with all other lights when key is in pos.II(bulb check),before starting the car?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: 240DL;850;S70
- Been thanked: 26 times
It looks more like the reflection from the bright adjacent warning light is lighting the battery warning light. But the battery light looks very dim compared to the one next to it. Where are you leading me with this idea?
- misha
If the battery warning light is burnt,open circuit,shorted to ground,or the thin wire which goes to the alternator above b+ terminal is disconnected or shorted... the alternator will NOT have the output.
That thin wire is signal for battery light on the dash and it also have "awakening" role for the alternator.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
So I could now be hunting for an issue with the thin wire? I am not good at tracing electrical shorts, this is getting deeper down the hole!
- misha
It's just the possibillity.
If the bulb is ok and signal wire(thin wire) is ok...than alternator(regulator)is bad.
It's easier to remove the cluster to check the bulb than to remove the alternator.
On that thin wire...you should have a battery voltage present with key in pos.II.
If you have voltage on it and bulb is ok....again...the alt. is bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: 97 854 T5
- Has thanked: 31 times
- Been thanked: 73 times
Now that you say that you don't have a Battery light on with key on, I just went through a similar issue on my '97 T5.
You probably also have a couple more lights that aren't coming on. From my post on it.
Upon inspecting the original alternator, the brushes on the regulator had worn down to where they were no longer, or barely, touching the slip ring. I never saw a low battery light "glow", so I think the regulator just gave it up.
You can replace the regulator while the alternator is in the car, but it's kind of a pain. Even more of a pain perhaps than just pulling the alternator.
I was going to swap the regulator, but the bearings sounded like so much gravel in the alternator, I just pulled another spare I had in the garage and installed it. After that, the car has run fine, and all of the lights work and it charges are as it should.I had gotten some weird dash lights on Wed (Low Fuel and SRS lights would flash on the interstate, and eventually came on when I got off the highway). When I got home I checked and I had no Battery light on key "ON". (Actually, no Battery, Parking Brake, Brake Warning, Bulb Failure lights). Taking the D+ wire (The small wire) to ground gave me all the appropriate lights, to the bulb was good, so the problem was in the alternator or regulator, and the odd lights were due to low battery voltage.
'97 854 T5 - Manual Swap, M4.4,COP, P2R Brakes, 16T, chassis bracing, XC70 nose swap
'97 855 GLT - Hers. RN swap/16T/exhaust/302s/Flashable M4.4, chassis bracing, 2 kid seats
Yes you may be correct. I hear a grinding, growling noise somewhere near the serpentine belt for a short time at start up.
Hey misha! I measured 7.5 volts on the thin wire with key pos II. Not sure if that means anything. FCEuro alternator is being shipped here.
Thanks again.
Carl
Thanks again.
Carl
