Did you know? 🤔
2001 V70XC - 200,000 Miles Makeover
2001 - 2007 XC-70
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 19 times
Been thanked: 36 times
United States of America
xHeart
Re: 2001 V70XC - 200,000 Miles Makeover
Post by xHeart » Thu Mar 19, 2020 8:02 pm
- Pete - wrote:
Thu Mar 19, 2020 1:48 pm
I forgot something - you can use I believe it is a 10mm ratcheting box end wrench on the shank of the T-55 to get the plug out of the exhaust VVT hub. Ultimately you’ll need to move the wire loom to get an accurate torque on the T-55 bolt that requires 88# torque though.
Thank you for sharing wire loom removal pix.
I'm all set to do the work. I will start with oil pump service.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
BlackBart
Has thanked: 68 times
Been thanked: 53 times
Sweden
BlackBart
Post by BlackBart » Fri Mar 20, 2020 12:16 pm
That's the ticket. Just don't crank those puny bolts down and sheer them off inside the camshaft.
1994 850T wagon
Is it time for a 1964 122 wagon?
xHeart
xHeart
Post by xHeart » Fri Mar 20, 2020 12:41 pm
Camshaft tool looks straight forward. I took a while for this beginner.
Now reached the oil pump, gave it a simple green 50/50 mix bath. I can turn the T-30 with stripping for next step.
xHeart
xHeart
Post by xHeart » Fri Mar 20, 2020 5:13 pm
Is there a special method of cleaning the oil pump?
- Pete -
Has thanked: 48 times
Been thanked: 64 times
- Pete -
Post by - Pete - » Fri Mar 20, 2020 5:50 pm
Just make certain you get all the old gasket material off. I used a dollar store kitchen sink scrubby/yellow foam thing. You don’t want to abrade the surface too much. Other than that just spray it out with brake parts cleaner & blow dry with compressed air if you can. Or dunk it in your simple green solution & let dry.
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
xHeart
xHeart
Post by xHeart » Sat Mar 21, 2020 12:01 pm
The paper seal was crisp - crumbled in to pieces. Watching a cleaned pump can be a joy in itself -- a bath in 50/50 mix of simple green.
- Pete -
- Pete -
Post by - Pete - » Sat Mar 21, 2020 12:20 pm
I agree! When you look at its design & see how it works it is very evident why these pumps are good to 500k & beyond.
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
xHeart
xHeart
Post by xHeart » Sat Mar 21, 2020 8:46 pm
Orange cone is a magical tool.
I installed the pump first and then the crankshaft seal using the magical cone.
- Pete -
- Pete -
Post by - Pete - » Sat Mar 21, 2020 10:32 pm
:lol:
How many tries did it take you?
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
xHeart
xHeart
Post by xHeart » Sun Mar 22, 2020 9:18 am
The four T-30 screws were coated with anaerobic sealant at the screw head.
The slit on the cone is a clue to watch as the seal transfers -- generous lubrication and 2 tries. Here is a set up of Pete Method:
