Did you know? 🤔
Torque spec for rear hub bolts. Topic is solved
jeffsws
Year and Model: 850 NA 1997
Has thanked: 2 times
Been thanked: 0
Sweden
jeffsws
Post by jeffsws » Wed Jan 29, 2020 11:12 am
Hello.
Do you know the torque spec for bolt 987377. I couldn't find anything on vida.
Cheers
Jeff
Richard99
Year and Model: 2000 V70XC
Has thanked: 6 times
Been thanked: 0
United States of America
Richard99
Re: Torque spec for rear hub bolts.
Post by Richard99 » Wed Jan 29, 2020 12:09 pm
Autozone procedure lists 49 ft/lbs + 60 degrees. I would always be slightly suspicious of these though. I know that the front hub mounting bolts on S/V70s 98-00 are 33 ft/lbs +60 degrees, per this forum.
https://www.autozone.com/repairguides/V ... 52801c1485
Eric
1998 Volvo V70
2000 Volvo V70XC
jeffsws
Been thanked: 0
Sweden
jeffsws
Post by jeffsws » Wed Jan 29, 2020 1:46 pm
Thank you.
I think hub might have been the wrong word to use. I guess that means wheel bearing in most cases? The wheel bearing on the rear is not held on by any bolts, other than the axle nut.
The bolts I mean are holding the actual wheel axle section. Part 9157713/9157714
jeffsws
Been thanked: 0
Sweden
jeffsws
Post by jeffsws » Mon Feb 10, 2020 1:20 pm
Any ideas on the spec? Or just very tight and then a bit?
Has thanked: 273 times
Been thanked: 851 times
Trinidad & Tobago
Re: Torque spec for rear hub bolts.  Topic is solved
Post by abscate » Tue Feb 11, 2020 4:33 am
I see lower torque in Alldata, 35 Nm and 60 degree angle
Note that new hardware is also specified.
These users thanked the author abscate for the post:
jeffsws
Link To Volvo Glossary
