2013 C30 Oil Capacity Question (70K Oil change)
BlackThunder
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 3 times
Post by BlackThunder »
Changed my oil and 6 quarts went in fine but the dip stick was still showing low. I ended having to add a whole quart more to get the dipstick to go to full.
Is this a concern? Should I attempt to drain some oil out? Like do it tonight before it gets cold again in Minnesota? It was so nice today and I needed an oil change so I was glad to get it done.
I know 6.1 is the full capacity and I thought it was odd that it took 7 quarts.
I drained 6.1 quarts out (1 big container, 1 small, .5 or so of another container).
Would the extra .9 quart cause an issue? I plan on changing this oil in 5,000 miles if it isn't freezing out.
Thanks in advance.
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
BlackThunder wrote: 02 Feb 2020, 15:20 I know 6.1 is the full capacity and I thought it was odd that it took 7 quarts.
Did you give it enough time for all the oil to drain to the crankcase? On level ground?
Check the oil level in the morning before you start the engine.
Active
Past
BlackThunder
Thanks! I ended up draining a little out. I hope the engine is ok. It sounds and runs fine.
Dustin
Dustin
2013 Volvo C30 T5
