For both the Driver's and Passenger's side mirrors on my 96 850 - they follow the console-nubs adjustment in every direction except 'Up'. I can tilt them left, right, down.. but neither of them will tilt up!
Obviously not a major drivability issue, but it is a minor quality-of-life fix I want to attend to, you've got to pepper yourself with some 'easy wins' between the big stuff to keep morale up!
Anyone have any clues what this could be from?
[850] Weird Mirror Adj. Behavior Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If it tries to go up but skips....it's stripped gears.
If it doesn't move at all in that position i would check the adjustment switch(es) and clean the contacts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2199 times
Like misha says, if the issue is a common one to both mirrors then it would point to a common issue. The only common issue is the adjustment switch for that direction movement.
ToriWhite
- Year and Model: 1996 850
- Has thanked: 20 times
- Been thanked: 6 times
misha wrote: 03 Feb 2020, 02:29 If it tries to go up but skips....it's stripped gears.
No 'skipping' behavior, no motor hum of even 'trying' to move.. courtesy of RobertDIY apparently the Window Switch cluster is only a couple T25 and an ounce of elbow grease deep in the center console, shouldn't be too hard to pull out. Haven't found any info on actually cracking open the cluster, where the actual contacts / switch stuff would be to clean.. guess I'll have to take pictures and make it!scot850 wrote: 03 Feb 2020, 12:41 The only common issue is the adjustment switch for that direction movement.
There should be info here somewhere on removing the center console. Not a particularly difficult job. There is probably less info on dis-assembling the switches. If anything like I recall it requires 3 hands and small strong fingers and safety glasses for the small springs that fly out and immediately disappear. May be easier to replace with a junkyard item.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
+1 on cleaning the contacts. my R does exactly the same once in a while.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Ca;you just bump up the mirror by hand and then adjust down with the motor to the correct position?
ToriWhite
abscate wrote: 04 Feb 2020, 03:37 Ca;you just bump up the mirror by hand and then adjust down with the motor to the correct position?
Was able to push it smoothly, had the resistance of a plate stuck on the surface of a bowl of peanut butter- didnt have to force it to skip teeth on the gears or anything..
still going to pull it apart with pictures / write-up.. just.. now that I can use my mirrors safely again, I can push that down the 'to-do' list, and get back to fretting over stupid smog error codes
When I had nine drivers, all of whom didn’t drive until the Mirrors were set, they had to deal with mirrors that froze either from age or cold, so this was a common scenario in our house. They were all very careful drivers though.
The boys next door didn’t know cars had mirrors...
- 603 Views
Last post by voom8
- 366 Views
Last post by mayorpeoria
- 592 Views
- 1623 Views
Last post by phils94850
- 1676 Views
Last post by 850_GLT_Owner
