Direct start of the parking heater
Rebranded
Year and Model: 2014 V60 D6 AWD
Post by Rebranded »
Hello and nice to meet you!
I'm having issues using the timer or the direct start option for the parking heater.
I will add a video link to exemplify it:
The parking heater works, as it heats up the car when in pure mode. I can hear it running and see the smoke.
Also the remote start doesn;t work.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Temperature 0° C ... Has the heater been running more then 50 minutes prior to trying the Direct start.
Active
Past
Rebranded
Post by Rebranded »
No. It's the same with negative temperatures also. This is just unlocking the car and trying to Directstart
RickHaleParker
Direct start via the information display
1. Press OK to access the menu.
2. Scroll with the thumb wheel to Parking heater and select with OK.
3. Scroll forward in the next menu to Direct start in order to activate the heater and select with OK.
4. Exit the menu with RESET.
Active
Past
Rebranded
Post by Rebranded »
I have done those, the issue is that preconditioning doesn;t start. As i understood there should be Directstart ON or OFF.
And I'm missing those.Tried to use the timer and same thing. It doesn;t start and there is no error message.
Rebranded
Post by Rebranded »
@RickHaleParker do you know the requirements for the preconditioning to start? can i find them written somewhere?
