Parts List updated 14FEB 2020
Valve Stem Seals 8517893
Volvo part number 272424. It is a kit that contains 24 valve stem seals.
Cam seals front 6842272
Cam seals rear 944310
12 Cylinder head bolts 6812347
CH Gasket 3531017
SP Seals 5 31401351
Gasket Kit 9855592
10 exhaust studs 982667
10 Exhaust nuts 985868
2 Flange bolts 982793
4 Exhaust falnge studs 978342
4 Exhaust Nuts 985921
Gasket 9135122 is this in kit above?
2 M8 bolts under IM 985184 Qty 4
Thermostat
Thermostat and housing screws, 6
PCV?
IM screws 982778 Qty 8?
8 6 pt screws 986009
1 Gasket 11994 in kit?
Cap 3501944 Bosch equivalent
Rotor 1367783
Plugs 8642660
Gallon Volvo Coolant
Lower hose 6842428
Upper hose 1335433
Reservoir hose 9445378
Connection pipe 3531391
Thermostat 271664
Thermostat bolts 8 986228
Mount Gasket 9463284 or 946327 ?? In kit ???
1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 439 times
- Been thanked: 1330 times
Re: 1998 V70NAM56 cylinder head job, winter 2020 "The Orange Mountain"
Link To Volvo Glossary
- Year and Model: 96' 850
- Has thanked: 66 times
- Been thanked: 45 times
Steve, when an engine overheats like this one, does one ever have to be concerned about the bottom end?
Btw, I am seriously impressed by your work.
96' 850 sedan, base, auto, pewter/charcoal, 117k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 216k miles
05' V70, 5-speed manual, loaded, mistral green/ tan, 150k miles
79' Ford Capri S, Euro Spec 2.8 V6, T9 5-speed manual
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 51 times
- Been thanked: 201 times
That's awesome that they have prices listed on the website, it's always nice to see small businesses like machine shops joining the 21st century!
00 V70R Venetian Red/Charcoal M56 Swapped 200k
03 S60 2.4T Silver/Black 118k
07 XC90 V8 AWD Sport Titanium Grey/Black 174k
92 245 Base White/Beige 249k
98 V70 GLT Black/Beige 205k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
00 S70 GLT Mystic Silver/Taupe 253k
91 944 Turbo Dark Green/Beige 175k
93 944 Base Beige/Beige 221k
98 S90- Silver/Gray 207k
95 850 GLT Tropic Green... crushed
01 S60 2.4T Black/Black 230k
88 744 Turbo M46 Beige Metallic/Beige 188k
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
- Has thanked: 129 times
- Been thanked: 362 times
I (and my internet) don't recognize that part number for valve stem seals. You know about viewtopic.php?t=71962 right?
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
I do now.
That’s why I put them up here
Thanks for this and you earlier support
Ok , $16 per exhaust stud to replace, just Labour
That seems like a lot for heat and twist?
Hey! I’ve got a practice engine !!
- smacknab
- Year and Model: 99 s70 NA Manual
- Has thanked: 73 times
- Been thanked: 21 times
Took me and a friend to break those, I've never heard a sound like that before..abscate wrote: ↑Thu Feb 13, 2020 2:13 pm My fingers and heart were warmed by the screech of the yielding head bolts -
These things were up around 200 ft lb of torque to break them. Brothers and Sisters, get your sharp socket, six point, on WELL before pulling on these. How will I ever measure 130 degrees of angle torque, he wonders?
I got a angle gauge for like 7-10$ at a parts store
99 s70 NA Manual - >225k miles
Mods: Accidental C70 Delta link, V70 Left Dog Leg
You also have to be careful to apply pure torque, not just pull on the wrench. You need to counter the pull force with a firm pressure at the socket point so that you don’t pull the socket off the head bolt and strip itsmacknab wrote: ↑Thu Feb 13, 2020 7:23 pmTook me and a friend to break those, I've never heard a sound like that before..abscate wrote: ↑Thu Feb 13, 2020 2:13 pm My fingers and heart were warmed by the screech of the yielding head bolts -
Oh how I love working on southern cars.... the studs usually drive right out with the nuts. If not, vise grips usually do the trick with a little PB blaster.
That seems like a lot, especially if there's more than one or two studs.
The head bolts on these engines are ridiculously tight... no other head bolts I've removed have been as tight as white block head bolts. They make a neat sound for sure!
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
99 BMW 528i
84 BMW 318i
01 Mountaineer 5.0
Omen minute low flame. $160 less a few bad boys saved. I think most will come out easily. Kudos to Volvo for high quality steel studs.
Worst problem was getting propane to light at 16F..can I get hazard pay, Mark?
Sorry about pic quality
- 9 Replies
- 583 Views
Last post by wizechatmgr
- 562 Views
Last post by precopster
- 417 Views
Last post by 93SCMax
