Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
MVS-Amazon link helps MVS!
does window on xc 2002 fit v70 2004?
2001 - 2007 XC-70
qwertyjjj
Year and Model: V70 2004
Post by qwertyjjj »
I broke my passenger window when the latch came undone and on trying to hold the window in place the arm, pushed it up or got caught somehow and cracked it.
The scrap yard has a place where you can pick up any part for $20 but they only have a V70 XC 2002.
I'm wondering if the window on that or even the entire door would fit a V70 2004?
jimmy57
Been thanked: 276 times
Re: does window on xc 2002 fit v70 2004?
Post by jimmy57 »
yes but there are standard glass and double pane. The 02 may have the double pane but it still works but is maybe 2 mm thicker. The std will break into crumbles since it is tempered. The double pane is regular glass that breaks into longer shards but is stuck to the binding plastic sheet and is harder for carjackers to break and threaten you.
qwertyjjj
Post by qwertyjjj »
Is the whole door the same (including electronic connections), because I could possibly ust remove the whole thing from the scrap yard
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 35 times
Been thanked: 86 times
Post by E Showell »
Entire door will fit, but exterior trim is very different.
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
Rattnalle
Has thanked: 20 times
Been thanked: 124 times
Post by Rattnalle »
And the door module probably has to be moved between the doors.
The window swap is a relatively easy affair iirc.
E Showell
Post by E Showell »
Window swap isn't too bad. Done one. Too bad it isn't your passenger side window. I have a rusted passenger front door that I removed from Ruby Red that has a good window glass in it.
'95 855 auto (sold)
BlackBart
Has thanked: 100 times
Been thanked: 102 times
Post by BlackBart »
I read this title as "Does a window from a BMW 2002 fit a V70....??" Sorry, lack of reading comprehension on my part!
I did this exact thing to my drivers window. Had Safelite replace it and it was way more than a windshield due to supply & demand. It was a surprise. My 2004 was a laminated safety glass.
1994 850T wagon
Is it time for a 1964 122 wagon?
E Showell
Post by E Showell »
This is where access to a yard really pays off. I bought a complete door $35, just for the glass. Easier to remove the old window with the used door laying flat on the kitchen counter (i.e., mechanic's workbench) as well.
'95 855 auto (sold)
Has thanked: 443 times
Been thanked: 1339 times
jimmy57 wrote: Tue Feb 04, 2020 10:00 am yes but there are standard glass and double pane. The 02 may have the double pane but it still works but is maybe 2 mm thicker. The std will break into crumbles since it is tempered. The double pane is regular glass that breaks into longer shards but is stuck to the binding plastic sheet and is harder for carjackers to break and threaten you.
Tough crowd down there, jimmy. I’ve heard they have been jacking the waterfall grills of cars at lights, but interestingly no interest in the egg crates
Link To Volvo Glossary
E Showell
Post by E Showell »
My '04 window was double pane.
'95 855 auto (sold)
