Currently my volvo v70 will not pass NY State Inspection. Hesitates on start-up. A general mechanic told me to replace both upstream and downstream 02 sensors and coil packs. Any suggestions or advice on this? I am new to volvo.
Thanks,
Dave
Replacing up& down02 sensors, coil packs
I’ve actually driven through Taberg, albeit I was lost, testing the theory that do all roads indeed lead to a Rome.
Greetings.
You are probably failing inspection due the presence of engine codes, stored in your engine computer, or ECM.
You need to read those codes and get the. Actual numbers like Pxxxx.
Most trouble codes are caused by vacuum leaks and broken hoses, occasionally plugs and coils go bad in these cars too. Hold off on oxygen sensors for now
Greetings.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How many miles ? Turbo? You only need to replace the upstream O2 for the emissions, but some mechanics are too quick to give simple answers. Can be other things other than a front O2 sensor. Give us more details if you have, and try to find the culprit with certitude. As for the coils, unless you have a lot of miles, just need to replace 1 or 2 when they fail - they will give a shake or missing. Use Bosch from Fcpeuro. More important is to have the correct spark plugs of the right brand.
- 2249 Views
- 854 Views
Last post by fixer333
- 665 Views
Last post by SuperHerman
- 1143 Views
Last post by Roger_850T
- 866 Views
