Did you know? 🤔
2004 v70 "BrakeFailure,Stop Safely"
2001 - 2007 XC-70
Faust
Year and Model: V70 2004
Has thanked: 7 times
United States of America
Faust
Post by Faust » Wed Feb 05, 2020 4:04 pm
I have an '04 V70 NA, which I have had for about a year. For as long as I can remember the "Brake Failure, Stop Safely" message has been on, the only ill effect I can recall is inoperable ABS in the snow. In fact the car would pull itself to the right making me think the left hand front brake was not operating at all.
Other symptoms:
Error Message
Red "BRAKE" light on dash
Yellow ABS light on dash
Possibly related, my odometer has become very spotty, registering about 12 miles over the last 200. Possibly speed sensor.
Brake master is full. Parking brake is inoperable, but probably adjustment.
I had it scanned at a parts store to day, it returned "no codes". I am wondering about the skill of the operator.
There does seem to be slight loss as I hold my foot on the brake pedal.
Thoughts?
- Pete -
Has thanked: 37 times
Been thanked: 57 times
- Pete -
Re: 2004 v70 "BrakeFailure,Stop Safely"
Post by - Pete - » Wed Feb 05, 2020 6:22 pm
My only experience with this has been a corrupted/failed BCM/ABS module (Braking Control Module).
Xemodex, one of the sites sponsors, is able to repair the modules. The price has come down over the years, back when it happened to mine it was around $600 w/expedited return shipping.
Last I checked it was noticeably lower than what I paid.
Like you’ve noticed, nothing really horrific happens, other than loss of ABS on slick stuff (which I suppose could be bad in some situations). I suppose traction control may be affected as well since the vehicle uses ABS to control wheel spin.
Canadian company with excellent service, turnaround time, and reviews.
https://xemodex.com/us/brake-control-mo ... -services/
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
Faust
Faust
Post by Faust » Thu Feb 06, 2020 10:28 am
I have an identical car with a blown engine under the barn. Any reason why I can't just switch modules?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 233 times
Canada
oragex
Post by oragex » Thu Feb 06, 2020 11:14 am
See first if it has the same STC vs DSTC. The modules may or may not work, have to test try assuming it has the same connector
Also see what others have to say about the issue, maybe it turns out to be a simpler fix, check reluctor rings while there for cracks
shiloh51933
Has thanked: 11 times
Been thanked: 9 times
shiloh51933
Post by shiloh51933 » Thu Feb 06, 2020 7:08 pm
Other symptoms:
Error Message
Thoughts?
Possibly wheel speed sensor but sounds like ABS module.
If U Wanna Play U Gotta Pay!!
- Pete -
- Pete -
Post by - Pete - » Thu Feb 06, 2020 8:25 pm
I didn't mean to scare you by posting that about Xemodex, my apologies. Your symptoms just sounded much like I recall mine as being.
Edit: I'd totally try swapping the BCM module into your running car. For the blind work you'll need torx bits, can't recall which size but quite long bolts come out, then the module just "drops" straight off the bottom of the ABS unit. Cleanliness is important here. I believe there is an informative video on Xemodex's site.
Here it is - https://xemodex.com/us/knowledgebase/bc ... 2002-2013/
Does your reservoir drop in level at all? Have you inspected every caliper where the hard lines come in (also bleeders) & checked each CV shafts center bolt (accessible by taking your wheel center cap off) for tightness?
Here is the ABS/BCM module failure flow chart by Xemodex.
https://xemodex.com/us/knowledgebase/bc ... 2002-2004/
In my case I was in the middle of nowhere & couldn't access BCM codes & so had to just send it in hoping they wouldn't need my pump as well. I was fortunate in that regard. BCM only repair is cheaper than both.
These users thanked the author - Pete - for the post:
Faust
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
Faust
Faust
Post by Faust » Fri Feb 07, 2020 7:00 am
Thank you. I had already discovered the video on removal, but the flow chart was helpful. As I mentioned, I had it scanned and received "no codes". That was done at an auto parts store and I suspected "fault of the operator". The flow chart mentions "no codes", or "unable to communicate". Flow chart suggests replacement of relays, otherwise send in BCM for repair. Since I have them, I will replace the relays. But it does suggest the BCM is the problem. My major character flaw is that I couldn't wire a door bell.
2004 V70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 49 times
vtl
Post by vtl » Fri Feb 07, 2020 7:43 am
Read the codes first using DiCE+VIDA. It may be as simple as rusted tone ring, lost axle bolt or less work-intensive brake pedal sensors. You may also have a corroded DEM that kills communication with BCM. just to scare you :) Numerous possibilities, read the codes.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
