Hello everyone
Turbo gauge wont pass more than 3/4 of the way around when accelerating. The car also starts to accelerate fast then surges almost like its hitting a limiter.
First component to look at?
I've not had the car long so dont know what has been replaced in its history.
Any advice would be massively appreciated
Cheers in advance.
850 t5 r turbo problems
Nicholls39
- Year and Model: 95 850 t5 r
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I think I'd first check your rubber intercooler hoses. I've heard that when they get old and soft, they will partially collapse when the turbo kicks in, basically clogging everything up.
1999 V70 GLT
1999 V70 GLT
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I agree with the above advice. In addition, it might be a good idea to check all the rubber vacuum lines, in particular those connecting to the boost control solenoid / turbo control valve.
- Has thanked: 312 times
- Been thanked: 818 times
And if those checks don't solve the problem, check the CBV diaphragm for tears, especially if it's never been changed. I actually might even look here first if it wasn't such a PITA to check. The hoses are easy and should definitely be inspected.
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Worn ignition components can cause that. Are your sparkplugs, wires, distributor and cap OEM quality and pretty newish? if not, this can cause erratic behaviour like you mentioned.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1220 Views
Last post by combatkarl
- 1045 Views
Last post by misha
- 913 Views
Last post by Unclejus1215
- 1443 Views
Last post by 93Regina
- 11 Replies
- 6173 Views
Last post by VTs70T5M
