dipstick tube O ring Topic is solved
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
I tracked down my oil leak to the dipstick tube O ring. I have a T5, BTW. What size should I get? one that seals real well. I hope to find one at the hardware store or auto parts store tomorrow.. Thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
The cross-section of the o-ring is rectangular. I think you could probably get round (cross-sectional) o-rings to seal (doubled or tripled up), but I think they will tend to "roll up" the dipstick tube as you insert it. Maybe if you can get the right size use 3 or even 4 just in case the top one rolls up too far.
This is OEM Volvo - https://www.fcpeuro.com/products/volvo- ... 30637865oe
This is aftermarket - https://www.fcpeuro.com/products/volvo- ... al-1397983
I've used both several times with success, so I'd say go with the cheaper.
O-ring dimensions are ID - 10.97mm (safe to say 11mm ID would work), 15.99mm OD, and a cross sectional width of 4.27mm.
Edit:
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
Ha-ha
My dipstick seal was old, dried and loose.
I bought a real, OE replacement seal.
After installation I landed the dipstick.
I tried pulling the dipstick and the red plastic part broke off leaving the stick in the tube.
So, I advise you clean the involved part of the tube so it's smooth inside. A touch of lube (oil, silicone) wouldn't hurt.
Also remember the plastic handle ages too.
I'd get a real seal rather than monkey around with O rings which may or may not be heat resistant.
If you go the O ring route see if you can find Viton O rings. They're dabbed with green.
azureblue
Post by azureblue »
I didn't know it has a rectangular profile - much thanks. Off to the dealer next week..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Check your PCV system for clog, this is how you get oil coming out of dipstick...
- At this age, sometimes it is better to get new dipstick, which is about $15-$20 at dealer.
The plastic can be detached from the handle.
