Xc60 blower motor
I have looked on here for info on my xc60 blower failing after being terrified about dismantling the interior of the car I was having a poke around and got mine working by poking it with a stick! Not very technical but did the job! I removed the battery cover looked through the bulkhead where the air intakes for the blower are and there were the fins of the blower so I got my rods out of my electrical kit and pushed it through to the fins gave it a push and it worked! Just an idea if your trying out ways to turn it without dismantling. Cheers
Shawshank08
- Year and Model: 2011 XC60
Could you post a picture of what you did? Or what cover you removed? I must be misunderstanding; I took the battery cover off and couldn't see a thing lol
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
on RH drive models that area is different. On LH drive models you remove the cowl cover (the panel the wipe arm shafts poke through in front of windshield) and with recirc off the blower wheel will be visible and reachable.
Shawshank08
I see- I'll give that a shot. I was just removing literally only the part covering the battery, but it sounds like more of the cover needs to be removed.
- 8341 Views
Last post by Mdquine
- 17 Replies
- 32199 Views
Last post by Dzikiewicz
- 5503 Views
Last post by RickHaleParker
- 1239 Views
Last post by 90cummins
- 1113 Views
Last post by geoffrow
