Did you know? 🤔
2007 XC70 start problem
2001 - 2007 XC-70
Mpdog37
Year and Model: 2007 XC70
Has thanked: 0
Been thanked: 0
United States of America
Mpdog37
Post by Mpdog37 » Sat Feb 08, 2020 2:41 pm
Strange starting issue with my 2007 XC70, turn key to start, cranks 3 times then stops, no start, turn key off try to start again, cranks 3 times then stops... any ideas why this could happen.
yagger
Year and Model: S60 2005 2,5T
Has thanked: 2 times
Been thanked: 15 times
Belarus
yagger
Re: 2007 XC70 start problem
Post by yagger » Sun Feb 09, 2020 1:55 pm
Not enough info. Show please errors from VIDA.
Volvo electronics and programming.Yagger&Doublebug - our experience invaluable.
Aftermarket Online Data Transferring Service for Volvo Pass: total
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Post by oragex » Sun Feb 09, 2020 2:07 pm
Same when jump starting ?
May also see the wires at the starter, also this one at the rad fan viewtopic.php?f=9&t=92688
Mpdog37
Has thanked: 0
Been thanked: 0
Mpdog37
Post by Mpdog37 » Sun Feb 09, 2020 4:26 pm
No diagnostic at this point, apartment mechanic, so can’t really disassemble much, got some stink eyes, checked grounds, and starter wiring, battery went dead, tried jumpbox, same thing, tried new battery, same thing, crank pulley marked and turning, compression seems good, doesn’t seem immobilized, I don’t know, will seek diagnostic and see what comes up... I’ve had (5) 122’s, and 3 v70’ wagons, this is first 21st century, and its over my head, give me a 4 banger and I’m all good, Lol....
Mpdog37
Has thanked: 0
Been thanked: 0
Mpdog37
Post by Mpdog37 » Mon Feb 24, 2020 5:18 pm
Ok, took to Volvo mechanic, trust him good guy, however code cannot be read, interior pops up, windows, lights etc, but engine side of CEM not readable, ugh! Recommends replacing CEM so code can be read, but at 1500 not gonna happen. I am going to pull CEM and use contact cleaner with brush and clean the hell out of connections, see what happens. Also, starter pulling too many amps, needs replaced, and ordered one. Question? Could starter pulling too many amps actually prevent the spark/ start?
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 56 times
vtl
Post by vtl » Mon Feb 24, 2020 7:16 pm
I would skip what good guy is suggesting for now, it smells like burnt starter.
Interference from dying starter hides crankshaft position sensor, which ECM uses for timing.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
Mpdog37
Has thanked: 0
Been thanked: 0
Mpdog37
Post by Mpdog37 » Mon Feb 24, 2020 8:08 pm
10/4...will let you know, thanks
RickHaleParker
Been thanked: 487 times
RickHaleParker
Post by RickHaleParker » Mon Feb 24, 2020 8:19 pm
Uh-uh ... sound like a CANbus issue not a CEM issue. I'm not so sure about that guy.
That is the correct path. Checking the CANbus from the CEM to ECM for shorts and opens is in order.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
Mpdog37
Has thanked: 0
Been thanked: 0
Mpdog37
Post by Mpdog37 » Sat Feb 29, 2020 8:00 pm
Well the plot thickens, contacted previous owner and CEM was replaced and programmed with new key and ignition and ring. I have new starter, pulled CEM, cleaned and will install tomorrow along with new battery. I used turn signal button search before pulling CEM and said ABS and immobilized, so will continue from there
Mpdog37
Has thanked: 0
Been thanked: 0
Mpdog37
Post by Mpdog37 » Sat Feb 29, 2020 8:04 pm
Does remote lock/unlock 5x reset immobilization on 2007 xc70?
