Hello all,
I have a 2004 XC90 2.5T and I love it. I recently had some issues and now I need some serious help. I had to replace the Fuel pump and Crank Position Sensor. Got the parts from FCPEURO. I then had codes that told me that both O2 sensors were bad. I got the Bosch sensors from FCPEURO again and was able to finally install them (had to fight the sensors to remove after multiple days of using PBBlaster on them). Once I got the sensors installed I get the 4 ECM codes listed in subject. I have run the car multiple days to see if the codes will clear and they do not. I did try to clear the codes with scanner and they keep showing up. I did not disconnect the battery prior to replacing the sensors. Is this an issue?
Any idea what this might be? I read somewhere that this might be a MAF issue. Any help is appreciated.
Thank you,
Keith in PA.
Multiple ECM Codes - 2A20, 2A2A, 2810 and 2A1A
keithhitch
- Year and Model: V70 XC 2000
- RickHaleParker
- Been thanked: 977 times
Check fuse 11B/4 in the engine compartment (Power to the O2 sensors heaters).
Active
Past
Past
keithhitch
I checked the fuse at number 11 and it is fine. I also cleaned the MAF with MAF cleaner. Any other ideas?
- RickHaleParker
Check again, 11B is the top side of the fuse box in the engine compartment. /4 is fuse number 4 of 11B.keithhitch wrote: 12 Feb 2020, 08:38 I checked the fuse at number 11 and it is fine. I also cleaned the MAF with MAF cleaner. Any other ideas?
Active
Past
Past
keithhitch
I will be checking 4 when I get home.
keithhitch
I rechecked both the 11B and the 4 fuse and both are the correct amperage and I still get the codes. When I start the car rear amperage is 0.45 and front is 1v. These do not change for a while until I get moving down the highway. They vary some but stay real close to the initial amperage. Is there any chance this might be a result of dirty contacts? I really am running out of ideas. What are the odds of receiving 2 bad O2 sensors from FCPEuro?
speedrcrjl
- Year and Model: 2004 xc70
Did you have a fix to this? I am having same codes with the same voltages
- 702 Views
Last post by dneu
- 1764 Views
Last post by RickHaleParker
- 1086 Views
Last post by sepress1
- 3803 Views
Last post by PixelDust
- 610 Views
Last post by Cees Klumper
