No spark at coil wire. Replaced cam and crank position sensors and coil with ignition module. Still no spark. Checked main engine relay and it is working ok. Gas is getting into the cylinders and also no firing with carb cleaner shot.
What else is needed to get fire to the coil? How does one trace it?
1998 S70 non-turbo cranks but no spark Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Fuses ok?
Check fuse for ECU(#1 on 850 don't know which one is for s70,but should be the same).
Any codes stored?
Any codes stored?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 778 Views
Last post by jeringo
- 4238 Views
Last post by BestNana1485129
- 19 Replies
- 3788 Views
- 18 Replies
- 10416 Views
Last post by Ozark Lee
- 20 Replies
- 1952 Views
