Did you know? 🤔
1998 S70 non-turbo cranks but no spark Topic is solved
jeringo
Year and Model: 1998 S70
Has thanked: 0
Been thanked: 0
United States of America
jeringo
Post by jeringo » Thu Feb 13, 2020 12:21 pm
No spark at coil wire. Replaced cam and crank position sensors and coil with ignition module. Still no spark. Checked main engine relay and it is working ok. Gas is getting into the cylinders and also no firing with carb cleaner shot.
What else is needed to get fire to the coil? How does one trace it?
misha
Has thanked: 49 times
Been thanked: 112 times
Serbia
misha
Re: 1998 S70 non-turbo cranks but no spark
Post by misha » Thu Feb 13, 2020 1:09 pm
Fuses ok?
Check fuse for ECU(#1 on 850 don't know which one is for s70,but should be the same).
Any codes stored?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jeringo
Has thanked: 0
Been thanked: 0
jeringo
Re: 1998 S70 non-turbo cranks but no spark  Topic is solved
Post by jeringo » Thu Feb 13, 2020 1:47 pm
Thank you. Will.
jeringo
Has thanked: 0
Been thanked: 0
jeringo
Post by jeringo » Sun Feb 16, 2020 9:01 am
Finally was getting a weak spark with plenty of starter motor action. Changed battery and cleaned cables and all ok. Test drive was good with plenty of power. Apparently fixed.
