Replacing waterpump 05 XC90 V8
nisan17
Year and Model: 92 940 turbo
Has thanked: 2 times
Post by nisan17 »
Hi members, I will be replacing a waterpump in my daughter's 05 XC90 V8. I haven't found any videos on youtube regarding same. Nor any other info online. Can one supply a link of instructions if possible. :?
Thank very much,
Kevin
Kevin
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
See the attached file.
2005 V8 Coolant pump and thermostat replacement.pdf
(1.62 MiB) Downloaded 881 times
Active
Past
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Aux belt comes off, not sure if there's a decent write-up on MVS but there's one here- https://forums.swedespeed.com/showthrea ... eplacement
Pay special attention to taking time to release the tensioner, it has a fluid filled damper inside the spring. Same goes for when you put the belt back on. If this vehicle has not had the belt, idlers and tensioner changed out (Volvo says 150k miles but there are a few reports of spun front cover idler studs at around 130k+), you really ought to consider doing the whole thing. Good time to swap out coolant as well, I use OE as it's comparable in price and I never have to wonder.
I had to replace a seeping PS pump a couple of months ago, did water pump and a bunch of hoses as preventative maintenance while I was in. Some photos for general reference (not a lot on the WP I'm afraid) - https://photos.app.goo.gl/biUK5fYifiYobj7g6
Good luck with your repair.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I just replaced the thermostat on our 2004 XC90 T6, while I had everything apart I replaced the thermostat housing, temp sensor, gaskets, 2 resevoir coolant hoses, coolant, clamps and installed a brass fitting after removing the plastic fitting that came with the new Volvo thermostat housing.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
