Trailer Hitch -- '04 XC70
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So, I picked up a used Volvo trailer hitch and wiring harness for Ruby Red. The tow bar has a bit of surface rust. Current plan is to remove scale with a wire wheel, wipe down with acetone, Rustoleum rattle can primer followed by Rustoleum gloss black. Treat afterwards with Fluid Film as rust protectant. Sound reasonable?
If not, what should I do differently?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
E Showell
Post by E Showell »
Changed to 80 grit sandpaper on a random orbital sander. May go to 60 grit.
'95 855 auto (sold)
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I had the towbar off our V70 AWD blasted & powdercoated for $65 I think it was. I have access to a big blast cabinet but for $65 I've got much better things to waste time on. They come powdercoated originally. I fear you will see rust fairly soon with rattle can. In MN we have to replace license plates at 7-year intervals because they rot out from salt exposure. I welded a receiver hitch cargo carrier & painstakingly primed & painted it. I bet I had at least a dozen empty cans, if not more. Rust still showed up very quickly, maybe a week or two.
This was prior to last winter & the car gets driven daily in the salt & slush up here. Still looks just as good as it did when I re-installed it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
E Showell
Post by E Showell »
Will sand to no rust visible, treat with some form of phosphoric acid solution to convert any remaining oxidation to zinc (or so I am told -- where's a good chemist when you need one?) Then rattle can primer with gloss over followed by fluid film. I am told Fluid Film is the next miracle cure. We'll see.
'95 855 auto (sold)
Has thanked: 1609 times
Been thanked: 4065 times
E Showell wrote: 18 Feb 2020, 14:28 Will sand to no rust visible, treat with some form of phosphoric acid solution to convert any remaining oxidation to zinc (or so I am told -- where's a good chemist when you need one?) Then rattle can primer with gloss over followed by fluid film. I am told Fluid Film is the next miracle cure. We'll see.
That would be a good paper, Fe----> Zn plus some energy I bet.
The rust converters haul the Oxygen away from the Iron, stick it onto the Phosphorus, then bind it up leaving a relatively inert
FePO4 instead of crumbly Fe2O3
E Showell
Post by E Showell »
So, before I do any more sanding, I may try rust removal with white vinegar and salt. Any spare solution I can use on my fish and chips (although malted vinegar would be better).
'95 855 auto (sold)
E Showell
Post by E Showell »
So, ferric phosphate as opposed to ferrous oxide, eh.
'95 855 auto (sold)
