Did you know? 🤔
Sub-woofer wiring advice ?
2001 - 2007 XC-70
Mikele82
Year and Model: XC70 2004
Has thanked: 24 times
United States of America
Mikele82
Post by Mikele82 » Mon Feb 17, 2020 3:15 pm
Hello,
trying to "simply" add a subwoofer to my xc70 2004.
so i got a 12inch woofer and enclousure box + amp + hi to low level converter
( https://catalog.pac-audio.com/catalog/a ... cing/lp7-2 )
was thinking connecting it to the speaker wire = tweeter in the D-piller, just up from the trunk left fuse box.
but now im understanding that this line for The tweeter wires are crossed over too high of a frequency.
so what would be the simplest path to connect the hi-to-low converter for the sub amp with a full spectrum audio/speaker wire ?
would it be routing a speaker wire from rear door speaker ,
or
is there a simpler path from full spectrum speaker wire to route all the way to the trunk ?
also, is there audio out on this rear fuse box?
the v70 has a REM diagram for subwoofer, is that somewere on the rear fusebox?
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 32 times
Been thanked: 23 times
EngineeringBloke
Re: Sub-woofer wiring advice ?
Post by EngineeringBloke » Thu Jun 25, 2020 4:33 pm
Hi, have you added your sub woofer yet?
While the diagram is for a 2007 model and yours is a 2004, it shows the unit at 16/79 is a subwoofer plus amp module.
That module gets power via 12v from the REM on B-17 and B-18, and ground via 16/79 lines 9 and 10. Those provide the power to run an amp to drive the sub. It looks like the amp is turned on via REM O-7.
The audio signal comes from the rear bass/mid speakers. I do not think there is audio in the REM itself.
Due to the dual 12v and grounds, it appears this is a dual mono (or stereo) sub system - it may have two speakers.
