Did you know? 🤔
There are only crickets in here...
All the classics... pre-1975 Volvos.
Year and Model: 2001 V70
Has thanked: 14 times
Been thanked: 41 times
United States of America
Re: There are only crickets in here...
Post by volvolugnut » Thu Mar 26, 2020 9:59 am
Okay, I think I can find the carbs here at the house. I need to make gaskets - can't find them to buy. Rest of car is in storage.
volvlolugnut
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
BlackBart
Has thanked: 68 times
Been thanked: 53 times
Sweden
BlackBart
Post by BlackBart » Thu Mar 26, 2020 1:12 pm
Just saw this.... Volvo Salvage in OK.
viewtopic.php?f=9&t=93412
These users thanked the author BlackBart for the post:
matthew1
1994 850T wagon
Is it time for a 1964 122 wagon?
Post by volvolugnut » Thu Mar 26, 2020 6:55 pm
Very good, I did not know about them. Not surprising though. Edmond (North side of Oklahoma City) is maybe the capital of Volvo interest in OK.
Today, I found the PV544 carb, and gasket material and hole punches. First 544 activity in years. Tag- your it.
BlackBart
Sweden
BlackBart
Post by BlackBart » Thu Mar 26, 2020 8:28 pm
You found BOTH of the Webers, and gasket material?? Fantastic!
1994 850T wagon
Post by volvolugnut » Fri Mar 27, 2020 9:35 am
No, I found one of the SU carbs. Pretty sure the other carb is in storage building.
BlackBart
Sweden
BlackBart
Post by BlackBart » Fri Mar 27, 2020 4:14 pm
Just kidding.
Found mine. Years of body shop dust and grime. Now I need to learn how to rebuild them. I actually only pulled them to get to the front suspension bolts on the right side. But they've been sitting so many years, they're probably gunked up.
1994 850T wagon
Post by volvolugnut » Fri Mar 27, 2020 4:32 pm
Looks like those Webers are missing a few bolts and cover plates. The internet knows all about these. On closer inspection of my SU carb, the choke linkage has lots of slop in the pivot points. Thinking I may fill the holes with epoxy mix and drill out to proper pin size. These linkage levers are cast brass and look really cool.
BlackBart
Sweden
BlackBart
Post by BlackBart » Fri Mar 27, 2020 4:44 pm
I just took it apart to look inside.
1994 850T wagon
BlackBart
Sweden
BlackBart
Post by BlackBart » Sat Mar 28, 2020 8:28 pm
Some actual progress!! Moved the other car out, the lawn mower, the shop vac, a transmission, and dug all this out.
It's a bit like reconstructing a crime scene. As I sorted through parts and pieces, I realized I had started to refurbish some of the bits, painted some, had some new bushings pressed in. So it's taking a while to verify what's old and what's new! I made notes on disassembly, and put stacks of washers and nuts on zip ties so the order is right, made some sketches. Lifesavers!
New bushings in lower A arms. New ball joint.
Old upper control arm and new adjustable control arm.
On this used upright I bought, which I obviously cleaned up and painted, I had a "speedi-sleeve" installed over a groove in the oil seal surface. I found later model 70's uprights and front hubs, which carry bigger Ate calipers. I'm changing the braking system from Dunlop to Ate, which includes swapping the rear axle.
I had to get at least one piece assembled so I felt like I was getting somewhere!
matthew1
1994 850T wagon
BlackBart
Sweden
BlackBart
Post by BlackBart » Sat Mar 28, 2020 8:49 pm
EVDH 122 meese.jpeg (136.93 KiB) Viewed 26 times
Volvo PV444 Brochure 1957 EN.jpg (149.97 KiB) Viewed 26 times
Volvo PV444 Brochure 1957 EN-1.jpg (114.76 KiB) Viewed 26 times
Volvo NYer comic.jpg (76.5 KiB) Viewed 26 times
1994 850T wagon
