best 850 heater core?
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Hi, I installed one of the Swedish Car Parts "Made in Europe" heater cores several years ago. It smelled pretty bad for the first year or so. Toward the end of the second winter it died down to where it was tolerable, but it hasn't really diminished at all since then. Mostly it's a hot plastic kind of smell with an occasional light whiff of coolant. Cooling system goes almost a year between top-ups.
What's the current state of thinking on heater cores? Can I get both low odor and longevity if I'm willing to pay for it? Are the recent ones from Swedish Car Parts any better? Behr? Nissens? Take out a second mortgage and buy OEM blue box Volvo?
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Get the Behr for about $80 on FCP. It's the OE part and should be just as good as the blue box. Nissens is also fine quality.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
850oldschool
ecbsykes wrote: 22 Feb 2020, 21:50 Get the Behr for about $80 on FCP. It's the OE part and should be just as good as the blue box. Nissens is also fine quality.
Have you used either of them?
FlyingVolvo
I have a Behr in mine right now going on 4 years. It's the OE part.
2023 V60 T8 PE
850oldschool
OK, thanks. Yes, I know Behr is a Volvo supplier, but at the time when I started shopping for one 5+ years ago I was reading a lot of stories of Behr cores failing, usually where the tubes were molded directly into the plastic. Thanks for your positive report.
Did you just take it out of the box and install it, or did you do any cleaning prior to installation?
FlyingVolvo
I didn't do anything to the core itself. If I recall there was a slight smell during the first use for a few minutes, but it was fine after that.
It's a bit more of pain, but last time I did it, I also preemptively replaced the connector pipe between heater hoses and the core (PN: 9134978). The plastic tends to crack with age and becomes brittle.
2023 V60 T8 PE
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Go with Behr I’ve had them last well over 200,000km
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
If you need to run another Swedish car parts heater core, do yourself a favor. Run that sucker through a single cycle in the dishwasher with the heated dry turned off on the top rack. You'll thank me later... =)
Has thanked: 1609 times
Been thanked: 4065 times
My second Behr is now at 8 years and 110k miles
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I also put in a Behr heater core back in early 2015. It has been working fine since.
