Did you know? 🤔
2005 XC70 Smell of gas (New to Volvo's)
2001 - 2007 XC-70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 56 times
United States of America
vtl
Re: 2005 XC70 Smell of gas (New to Volvo's)
Post by vtl » Thu Feb 27, 2020 8:56 pm
I hope you see the picture. Box with a cross is the canister, white box to the right - EVAP diagnostic pump.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
- Pete -
Has thanked: 48 times
Been thanked: 65 times
- Pete -
Post by - Pete - » Thu Feb 27, 2020 9:53 pm
This sounds much like a leak I had back in January of 2016 on our 04 XC70.
The culprit was a wire that had been carelessly left laying across the green gasket that seals the top of your fuel tank in the exact location you mentioned seeing the leak/smell emanating from. Definitely have a look at the top cap/gasket underneath!
On ours, we owned the car 4 full years before it started smelling frequently like fuel. If I only filled it up part way the smell/leak was much less noticeable. Once I righted the wire/seal, problem gone. I have the tool if you want to borrow it. Just pay for shipping. You can make it out of PVC if you want to, Bart made his out of 4" I believe it was.
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
RickHaleParker
Been thanked: 492 times
RickHaleParker
Post by RickHaleParker » Thu Feb 27, 2020 10:27 pm
wczimmerman wrote: ↑
Thu Feb 27, 2020 8:48 pm
Does anyone have a picture of the evap canister so I know what I'm looking for?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
wczimmerman
Has thanked: 0
Been thanked: 0
wczimmerman
Post by wczimmerman » Fri Feb 28, 2020 8:57 am
MANY THANKS to everyone for the assistance!
Pete: I will shoot you a PM. I need to figure out what weekend I will be doing all this.
wczimmerman
Has thanked: 0
Been thanked: 0
wczimmerman
Post by wczimmerman » Fri Feb 28, 2020 9:37 am
vtl wrote: ↑
I do see it. So, drop the exhaust and remove the heat shield should reveal that canister? Then I just check the lines for signs of leakage.
vtl
vtl
Post by vtl » Fri Feb 28, 2020 11:30 am
Yes. You will have very little access to the hoses, may need to lower subframe partially for better access. Unbolting one corner takes it down for 2-3 inches.
On older P2 (2002) there was a prominent rubber-made J-hose attached to the canister that was drying/cracking. Don't remember if 2005 has it or if it's made of rubber or plastic, I simply could not take canister out. At the end the source for a "large leak" detected by computer was EVAP diag pump, which died.
wczimmerman
Has thanked: 0
Been thanked: 0
wczimmerman
Post by wczimmerman » Fri Feb 28, 2020 12:16 pm
vtl wrote: ↑
How were you able to determine the pump failed?
vtl
vtl
Post by vtl » Fri Feb 28, 2020 2:42 pm
Diagnostic (in VIDA) was not starting, vacuum was not increasing. Perhaps, car software thought: "Ouch, can't create any vacuum, it must be a large hole".
