Did you know? 🤔
Aceleration problem from start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
MALL240
Year and Model: 1990 240 2.3 GTL
Has thanked: 28 times
Been thanked: 0
Spain
MALL240
Re: Aceleration problem from start
Post by MALL240 » Fri Apr 17, 2020 9:23 am
Hi, I disconnected the O2 probe and the car works the same way, nothing strange... I'm afraid the probe must not be right...
Edit: I also bought dashboard lights (motor lights) 12V 1,2W and two uds 12V 3W
:shock:
MALL240
Been thanked: 0
Spain
MALL240
Post by MALL240 » Mon May 04, 2020 10:22 am
Hi, I replaced the CO2 probe and the car is doing better, along with the TPS sensor. It was a bit cold and it still backfires a bit if I give it gas hard and then some excess gasoline backfires...
I have put the bulbs of the panel and, surprise, the one with the lights comes on, the first one from the left and the second one, light and lambda...(edit)
I'm going to investigate, but I've already seen that I don't have the relay of the lights that goes down on the pedal, the lights work... so I imagine that it jumps because the relay is not there?
I don't know if I'm wearing a blue belt, I don't think I'm wearing a blue belt...
Thank you very much.
RickHaleParker
Has thanked: 3 times
Been thanked: 538 times
United States of America
RickHaleParker
Post by RickHaleParker » Mon May 04, 2020 11:26 am
As old as the car is, it is bound to have some air leaks which can be the source of the backfire. I suggest you smoke test the intake and exhaust system. Fix any leaks you find. Keep in mind a lot of .01s add up.
These users thanked the author RickHaleParker for the post:
MALL240
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
MALL240
Been thanked: 0
Spain
MALL240
Post by MALL240 » Mon May 04, 2020 11:34 am
Thaks Rick! the Lamda light it's the CEL no? 5 minutes and the light goes on... check OBD and i have the same 2-1-3, 1-1-3.
A lot of cables off
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon May 04, 2020 11:58 am
The unconnected cables most likely are options you do not have. Inspect them with a Loupe for scratches on the metal contacts.
Scratches = been used before. No scratches = never been used.
MALL240
MALL240
Been thanked: 0
Spain
MALL240
Post by MALL240 » Mon May 04, 2020 12:22 pm
Ok!!!!
in the green book say too: 1-1-3 - Fault in injector (Break in lead. clogged. etc..) tha cables look news... maybe the injector
Throttleswitch; full load setting faufty. possible groundlllg short becouse the TPS sensor is new.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon May 04, 2020 12:58 pm
Got a Oscilloscope or or a Logic probe? Probe the signal on each injector.
If it was wiring I would expect misfires also.
A fresh set of remanufactured injectors is not a bad idea, US$50 - US$60 per set.
MALL240
MALL240
Been thanked: 0
Spain
MALL240
Post by MALL240 » Mon May 04, 2020 1:28 pm
I checked with a voltmeter the connections 9 and 18 to see the ohmm, I put it in 20 and the result was 003.
Buying the injectors is going to be a good thing.
Thank you, Rick. Let's see if I can get this thing to run smoothly.
nmontague81
Year and Model: '96 854, '93 945
Has thanked: 0
nmontague81
Post by nmontague81 » Thu May 21, 2020 8:45 pm
If it still has problems, check the air intake hose for cracks. Also check the idle air hoses for cracks and make sure all of the hoses are clamped down securely.
Maybe check the fuel lines under the hood to make sure they're not leaking.
These users thanked the author nmontague81 for the post:
MALL240
MALL240
Been thanked: 0
Spain
MALL240
Post by MALL240 » Fri May 22, 2020 12:02 am
Thanks NMontague , i tried to make the smoke machine, but i did wrong... i have to try again...
