Loaned my car to a friend in need for a week and he called me last night with a no crank problem
Dash lights come on, clink of relays, no cranking
I an 8 minute call I...
Guided him to front, opened kidney fusebox
To rear, opened my in-car tools, opened the creamchesse container and retrieved my pre-made remote starter bypass wire
Hooked it into white terminal
Confirmed Neutral
Touched to battery
Vroom!!!
We are debating if it has an ignition switch, clutch switch, or perhaps starter relay issue.
More to come
Link to remote starter thread
viewtopic.php?f=1&t=78989
The Boy Scouts are proud of me today...even if they are bankrupt. They are out of money, too.
1999 V70 T5 M56 ELIZABETH No crank Problem [9472949 clutch switch ] Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
He going to have that at work tomorrow? I may head out that way to sight in a "toy."
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I'm just stunned that you would loan that car, TBH.
It’s just a thing. A thing that is helping out a guy who has helped me out on many occasions.
Interesting failure mode to be discussed
- Has thanked: 311 times
- Been thanked: 817 times
My guess is ignition switch. Awaiting discussion!
I think Professor Volvo is on point.
Follow up. Friend reports he has to trigger starter with the white terminal while also holding key in POS III, crank position
I hAve previously started car with the remote terminal in POS II with no problem
I’m guessing this points to an ignition switch problem. Current one, 7 years, 110k miles
FCP baby!
Hard to buy your next part anywhere else when you see FCP's warranty come through like that.
Heh heh.
Get your thinking caps out on this one.
Car energizes but does not crank in pos III
If we jump to the remote bypass terminal (RBT) under hood, car cranks but does not start
If we jump RBT, AND turn key to pos III, CAR starts
......and......
If we leave a remote starter switch connected to the RBT, BUT DONT ACTIVATE IT, the car starts in key position III.
This one should be fun.
......and......
Sounds fun but I'd leave my thinking cap in the closet for a bit and replace the switch. Gasp(!) throw a part at it. Bad ignition switch is well known to cause bizarre electrical behaviors.
Don't you have a good switch from another car you can test with?
Exactly. Parts darts are called for here. I think on the 1999 there is both electrical connection and logic going on in the starter circuit. The starter relay actually gets it trigger from the 2/76 lock control module, which gets the start command from the ECU.erikv11 wrote: 28 Feb 2020, 09:01 Sounds fun but I'd leave my thinking cap in the closet for a bit and replace the switch. Gasp(!) throw a part at it. Bad ignition switch is well known to cause bizarre electrical behaviors.
- 21 Replies
- 5921 Views
- 303 Replies
- 37365 Views
Last post by bmdubya1198
- 12 Replies
- 1478 Views
- 1635 Views
- 49 Replies
- 10790 Views
