Did you know? 🤔
1999 V70 T5 M56 ELIZABETH No crank Problem [9472949 clutch switch ] Topic is solved
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 34 times
United States of America
callahanoffroad
Re: 1999 V70 T5 M56 ELIZABETH No crank Problem
Post by callahanoffroad » Fri Feb 28, 2020 1:08 pm
This makes me miss my old Landy Cruiser. You could hand crank the crankshaft with the key in run to start it. Logic circuit and wiring? Dang. Too much kerfuffle for me!
Has thanked: 315 times
Been thanked: 971 times
Trinidad & Tobago
Post by abscate » Fri Feb 28, 2020 7:49 pm
Well, here is the troubleshooting report
Car won’t crank in posIII
Jumping it at the bypass connector, car cranks and starts. Behaviour changed since last report
Quick swap of J relay, no change.
Tested terminal 86 , trigger signal on starter relay, goes to 12,3 Volts on key position III.
Tried new ignition switch, no change.
Fire up VIDA
21 start cycles showing clutch switch faults in VIDA, clutch signal out of range.
We ran out of daylight and cold at this point, but I had time to find my spare clutch switches.
Note the1999 starter circuit. The J relay gets12 volts trigger from the key I posIII, BUt the terminal 85 side of the trigger has to be grounded by the 2/76 lock module , after getting the right logic inputs from the ECU
Link To Volvo Glossary
Has thanked: 94 times
Been thanked: 276 times
Post by erikv11 » Fri Feb 28, 2020 10:01 pm
Oops it is a manual. I never even thought about the clutch switch ...
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
Trinidad & Tobago
Post by abscate » Sat Feb 29, 2020 3:56 am
The fault is almost persistent, but about e/(sqrt( alpha)) the car starts normally. Alpha is the waterfall fine structure constant of approximately 147.
That upset our diagnostic fu.
I confess to parts darting the J relay because it was so easy ( and I was parked next to another car with the same relay)
I am also allowing the possibility of logic failure as the clutch errors in VIDA could be generated by the use of the remote starter switch
Trinidad & Tobago
Post by abscate » Fri Apr 17, 2020 8:03 am
Looping back on this no crank problem.
I got my car back from my friend and it’s really interesting
No crank on pos III, just the BOINK of the internal relays.
But.... If you put in neutral and turn to position III and wait 5 seconds , it cranks and starts with the clutch engaged
Forgot to add, we swapped In a brand new ignition switch and no change to problem or symptoms. Before I had a chance to send back to FCP, my favorite lawyer in NJ needed one so I sent it to him
Trinidad & Tobago
Post by abscate » Fri Apr 17, 2020 10:34 am
Well, replaced clutch switch with known to be good
Car now cranks with clutch on floor
It also cranks after a 5 second delay with clutch engaged
Waiting for some M56 owners to test this on other cars.......
Update,...it looks like this is special on my car... 8)
Clutch switch tests out close to Specs, searchable here under part number 9472979
Clemens
Has thanked: 93 times
Been thanked: 53 times
Austria
Clemens
Post by Clemens » Sun Apr 19, 2020 12:47 am
Just an idea: get rid of the clutch switch. This should be possible. The EU spec cars have no clutch switch, so simply bridging the wires shouls work, I guess.
Still weird that it does that 5 second thing.
But then maybe, it only powers that wire for 5 seconds and you never noticed it because you are yoused to pressing the clutch when cranking anyhow.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Trinidad & Tobago
Post by abscate » Sun Apr 19, 2020 4:53 am
I thought that too, Clemens. I checked with a few other M56 owners and they report no cranking.
The change in resistance from clutch out ( foot off) to clutch in ( foot down) is 3000 ohms to 300 ohms
The ECU must look for a certain current. On the 1999 the clutch switch has two direct connections to the ECM
I know from previous experimentation that is unlatched logic, if you sit with the key in position iii , you can toggle cranking by depressing and releasing the clutch. I don’t think I held it long enough to test the 5 second cranking, though,previously.
Trinidad & Tobago
Post by abscate » Mon May 18, 2020 3:07 pm
Finally replaced that clutch switch
It measured 477 Ohms closed, and about 1 cm from end of travel it reached 3800 Ohms, then went open circuit
This caused a clutch switch permanent fuault and apparently also allows the ECU to crank the engine after 5bseconds of POS III
This also disable cruise control on ME7 as the same switch is used for clutch dropout,
In short, a new switch cleaned everything up
Has thanked: 11 times
Been thanked: 208 times
Canada
Re: 1999 V70 T5 M56 ELIZABETH No crank Problem [9472949 clutch switch ]
Post by scot850 » Mon May 18, 2020 3:40 pm
You should be really proud of getting to the end of this one! Totally impressed.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
