Hello All
hopefully someone can help me with this.
I have a message that my brake fluid level is low stop safely with a large triangle in the center display.
My brake fluid is full , was slightly low but filled up disconnected battery to reset but still the same message.
The brakes feel fine and I checked the pads on front when I pulled head to do the bent valves, that was a adventure in it self !!
Hopefully someone has had this issue and knows the cure to the triangle and the message.
Thanks all for any input.
Wes
Brake Fluid Level Low Message 2008 Volvo S40 but lvl full
Well I finally found the problem after checking the Float
Seems I had a little friend help me out during the night
The little rodent chewed through the wires going to the Lvl indicator float repaired all is well now!
Thanks
Thanks
- 1160 Views
Last post by erikv11
- 502 Views
Last post by MOZKNBBUHD
- 23 Replies
- 3502 Views
Last post by 5rivers
- 425 Views
Last post by Pennybags
- 1906 Views
Last post by fisker247
