IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Suspension noise Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 55 times
Been thanked: 77 times
United States of America
- Pete -
Re: Suspension noise
Post by - Pete - » Wed Mar 04, 2020 2:59 pm
The end links can be evasive little buggers. Sometimes you truly can’t “feel” if they are bad until you have them off the car. You can usually tell which side is bad/worse, but I would still replace both if you are setting out in that direction.
Don’t put Chinese suspension parts in the front of these cars. I’d need to look, but I’m pretty sure I am running Meyle HD links in 3/4 of our P2’s. They are made in Turkey.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 266 times
Canada
oragex
Post by oragex » Wed Mar 04, 2020 4:11 pm
The two videos do indeed sound pretty similar. As above, it's not always obvious, sometimes it's just the upper bolt not tight enough. Meyle HD is decent for this part, Lemforder should also be good. Upper bolt is tricky, lower one takes a grinder right away www.youtube.com/watch?v=zg8e5vKdgbI
Try to look at the spring seats from above www.youtube.com/watch?v=kj4JmZS2yM4
May also consider the noise may not come from the suspension, could as well be something inside the dash or doors - yet still 'sounding' like coming from the outside, but I would think end links have a good chance
RickHaleParker
Has thanked: 3 times
Been thanked: 543 times
RickHaleParker
Post by RickHaleParker » Thu Mar 05, 2020 10:25 pm
1. Open hood.
2. Stand on the side of the car near Wheel well.
3. Grab Wheel well.
4. Fix your eye on the top of the strut.
5. Bounce car up and down.
6. Observe strut mount. If the strut mount is broken you will see it.
7. Repeat 2 - 6 for the other side.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 29 times
Been thanked: 69 times
MoVolvos
Post by MoVolvos » Fri Mar 06, 2020 2:00 am
For any part that has a rubber boot that you suspect is bad due to age, try injecting some grease into it with a small needle. Has help postponed CV axle, bushing and sway bar link replacements. It can also potentially help eliminate sounds which were not traceable to anything obvious.
Did this to all the bushing our 2003 Lexus GS300 and the car became super smooth and quiet on the road as if it were riding on oil. Other uses were for a leaking inner CV joint on an 03 Odyssey and the sway bar links with cracked boot.
Plews 05-037 Grease Injector Needle $2.49
https://www.amazon.com/Plews-05-037-Gre ... 96&sr=1-20
Grease Gun Needle.png (371.58 KiB) Viewed 80 times
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
MoVolvos
Post by MoVolvos » Fri Mar 06, 2020 2:42 am
Sway Bar Bushings? The video reminded me of my brother's 93 850 which he purchased new. It developed a creak / snap in the front which the dealer had trouble figuring out. I was at Pep Boys in 94 so had him bring the car over so I can rack it. Turned out to be a broken bolt on the front sway bar clamp.
SWAY BAR BUSHING DIAGNOSIS AND REPLACEMENT | FIX ANNOYING NOISE
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
d0nahuge
Year and Model: 2007 Volvo S60 2.5t
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Sat Mar 07, 2020 12:38 pm
Update for everyone:
I replaced the sway bar links with some Meyle HD's and the noise is still there. Did a bounce test while looking at the strut mount and there was no major signs of anything wrong. I think it could be the sway bar bushing. I'll make sure to check the bushing with a pry bar. If I were to buy a sway bar bushing where would I get one? FCP does not carry one for my car (2007 Volvo S60 2.5t)
oragex
Canada
oragex
Post by oragex » Sat Mar 07, 2020 2:58 pm
My sway bar bushings are worn and knock but it's a completely different noise. Maybe a worn strut ? Any leaks ? Are they original ? Should have a Volvo/Sachs sticker on the hidden side, can use a mirror.
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Sat Mar 07, 2020 3:01 pm
The struts are original (I have 80k miles). Theres no sign of leaking and they aren't greasy. There is a good amount of rust on the strut. Is 80k miles too early for struts?
MoVolvos
MoVolvos
Post by MoVolvos » Sat Mar 07, 2020 4:15 pm
Strut Bearing Noise?
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
d0nahuge
Has thanked: 0
Been thanked: 0
d0nahuge
Post by d0nahuge » Mon Mar 09, 2020 6:00 pm
I missed it the first time, but my upper spring seat on the passenger side has a huge tear in it. Looks like you guys were right.
