2010 xc60 piercing sound
Anyone heard this before? Another symptom that is new is if you are sitting in park and blip the throttle it will hold at 2000rpm until you blip it again or put it in gear. That happening is not consistent though. This morning it was 50 degrees and the squeal is not as loud as the video. Maybe a vacuum leak of some kind, especially with the odd throttle response? There is no check engine light and no engine codes.
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
With engine idling and squealing, pull the dipstick out a few inches to see if it tops. If it does the crankcase breather assembly on top of engine has a failed diaphragm in the crankcase pressure regulator device.
So, I am thinking that I can put a zip tie on the dip stick to hold keep it from sealing to vent the vacuum, and not damage the engine so I can get it home?
- 2216 Views
Last post by tehniemer
- 1573 Views
Last post by raimuosius
- 8327 Views
Last post by Mdquine
- 1169 Views
Last post by sandyegg
- 1335 Views
Last post by Mousey
