Motronic 4.4 immobilizer
radek93
Year and Model: S70 98
Has thanked: 2 times
Been thanked: 3 times
Post by radek93 »
I have S70 2.5t 98r. How works immobilizer? Immobilizer module take signal from key and send info to engine ecu? Can I change engine ecu without immobilizer cut?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Up to '99 immobiliser reads the code from the key and just sends OK signal to ecu.
Basically....key communicates ONLY with immo2 box and then immo2 box sends OK signal to ecu.
Key(chip in it) is only married to immo2 box module.
That said...up to '99 you can swap ecu since it's not married to the car.
BUT....you will need ecu with the same BOSCH numbers because of software difference with M4.4 management.
Late 850 like mine also have M4.4 from the factory,but it's non-turbo.
You will need ecu from LPT 850 with M4.4 or from '97 & '98 s,v70 for LPT engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
radek93
Post by radek93 »
misha wrote: 05 Mar 2020, 13:59 Up to '99 immobiliser reads the code from the key and just sends OK signal to ecu.
Approx. So all I have to do is buy a computer with b5254t and it should work?
misha
Post by misha »
Yes...but Bosch numbers from original ecu needs to be exactly the same on a replacement ecu...year too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Where are you from?
1997 850 GLT B5254T and s,v70 2.5T(B5254T) from '97 & '98 have the same engine and management(M4.4).
So...ecu swap between those two cars for EU spec.will be plug and play as long as Bosch numbers match.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
radek93
Post by radek93 »
misha wrote: 05 Mar 2020, 14:09 Where are you from?
Poland. Ok. Thank You.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
radek93 wrote: 05 Mar 2020, 14:03 Approx. So all I have to do is buy a computer with b5254t and it should work?
Look at your ECM. You will find a software number in the format "0 261 204 XXX".
You need to find a replacement ECM with the same software number. All ten digits must match.
Active
Past
misha
Post by misha »
RickHaleParker wrote: 05 Mar 2020, 22:10 Look at your ECM. You will find a software number in the format "0 261 204 XXX".
That would be a Bosch part number(10-digit number).
Software numbers are under bar codes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
misha wrote: 06 Mar 2020, 02:16
All Bosch M4.4 hardware is the same. The only difference between one Bosch M4.4 part number and another is the software. That is why the tuners call out the software version by the last three digits of the part number. Match the numbers as I outlined above and the software will match. It is that simple.
Active
Past
misha
Post by misha »
Nope.....
https://www.google.com/search?sxsrf=ALe ... ZVxo_UDmQM:
Software version is somewhere under those bar codes.
Bosch 10 digit numbers indicates just part number for ecu.
Those numbers are the same and software numbers(codes) are different.
As you can see from the picture...last 3 digits from Bosch part number (10 digits number)doesn't match with any number under the bar codes.
I have somewhere in my computer a data where exactly is softvare version,but i'm on the phone now.
I'll post it if you want to see yourself.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
