Did you know? 🤔
1998 V70R brake work , What and how to clean in the mean time?
TheOtherside
Year and Model: 1998 V70R
Has thanked: 39 times
Been thanked: 3 times
United States of America
TheOtherside
Re: 1998 V70R brake work , What and how to clean in the mean time?
Post by TheOtherside » Fri Mar 06, 2020 11:59 am
Aw yeah... that legit looks like something I could do!
98 V70R
13 Flex w/EcoBoost
Has thanked: 9 times
Been thanked: 192 times
Canada
Post by scot850 » Fri Mar 06, 2020 12:14 pm
Somewhere in a box in a 10' x 10' storage building I have a pair of used OE lines I replaced on a 98 V70 XC. I was told that they were leaking so replaced them to find the leak continued. The dealer had 3 goes at fixing it, and said that was the only way to fix it. What I found is that it was not the lines leaking but the 'O' rings where the pipes meet the oil thermostat. Oil leaks from there due to poor design of the clamp that holds them in place. Over time the plate bends outwards on the ends and does not hold the pipes fully home in the thermostat. This allows the pipes to leak around the oil seals when they harden. What then happened was the dealer mechanic replace the 'O' rings but did not see that there was a build up of crusty hardened oil in the 'O' ring recess. Pushing the pipes back in just tore the new 'O' ring so the leaks continued.
I ended up removing the thermostat housing and fitting a new gasket as it was sweating a little, and very carefully cleaned the hardened oil out of the pipe/'O' ring recess.
I fitted the new pipes as I was in there anyway, but kept the old ones 'just in case'.
Not sure I can even access them until I build my new garage later this year, but if anyone wants them and is not in a rush I can ship them to you as I have no need for them.
I wish you luck with your adventure.
These users thanked the author scot850 for the post:
TheOtherside
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
TheOtherside
TheOtherside
Post by TheOtherside » Fri Mar 06, 2020 4:23 pm
Stripped both FL caliper bolts.....
Anyone have the part number?
98 V70R
13 Flex w/EcoBoost
Has thanked: 289 times
Been thanked: 905 times
Trinidad & Tobago
Post by abscate » Fri Mar 06, 2020 7:00 pm
Punch your vehicle info onto Volvo web store , make sure you choose the R variant on the brake schematic
These users thanked the author abscate for the post:
TheOtherside
Link To Volvo Glossary
Has thanked: 91 times
Been thanked: 264 times
Post by erikv11 » Fri Mar 06, 2020 8:31 pm
These users thanked the author erikv11 for the post:
TheOtherside
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
TheOtherside
TheOtherside
Post by TheOtherside » Sat Mar 07, 2020 8:48 am
Ordered!
98 V70R
13 Flex w/EcoBoost
Canada
Post by scot850 » Sat Mar 07, 2020 2:01 pm
Part is not unique to 'R' models. The caliper bracket is larger as is the disc, but the hub mounting point is the same as other P80 models.
TheOtherside
2006 XC70
TheOtherside
TheOtherside
Post by TheOtherside » Sun Mar 08, 2020 11:17 am
Dont hold the brakes with the caliper off the rotors....
Did I fuck these up???
98 V70R
13 Flex w/EcoBoost
Trinidad & Tobago
Post by abscate » Sun Mar 08, 2020 12:19 pm
I’ve got a set of T shirts of that mistake
Clean them up, get the piston back into the cylinder and reseat the seal and they will be fine
Nitrile gloves, brake fluid is bad for you.
Canada
Post by scot850 » Sun Mar 08, 2020 12:20 pm
Hard to tell where the fluid is coming from. The piston looks like it may have over extended as the dust seal looks like it has come out. Did you press the brake peddle by accident?
Pipe does not look wet so don't think the pipe is the issue.
2006 XC70
