Been having releasing problems with all seatbelts on my 2001 v70xc getting stuck, and complaints from passengers not being able to get out.Its very annoying but also dangerous.Had the exact same issue with my previous v70t5 ended up buying new from Volvo but after 6months it was also getting stuck.
So ive attempted to fix this a few times with short term success first was too take apart clean and lube..2nd attempt was to replace throw out spring but was expensive hard to find correct spring thats not too tensile, 3rd attempt today was to add a small section of cut off original spring. Now i press the release button and the belt pops up about an inch into the air. Ive done all belts, i think this fix will last.
This is the throw out spring that pops the buckle and locking latch out (click that you hear)
The front seatbelt casing slides apart where the rear casings are glued. the casings are interchangable, probably glued to prevent kids opening them?.
19yr old seat belts that pop
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 1460 Views
Last post by skippy764b
- 1175 Views
- 286 Views
Last post by jonesg
- 2523 Views
Last post by zwieback
- 20 Replies
- 3497 Views
Last post by xHeart
