Did you know? 🤔
What do you think? Topic is solved
2001 - 2007 XC-70
- Pete -
Has thanked: 48 times
Been thanked: 64 times
United States of America
- Pete -
Re: What do you think?
Post by - Pete - » Sun Mar 08, 2020 1:28 pm
Crunch crunch. It tends to happen in winter.
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
Has thanked: 285 times
Been thanked: 898 times
Trinidad & Tobago
Post by abscate » Sun Mar 08, 2020 6:04 pm
Worst case it ****might**** need another 1500-2000 to refresh everything to new. From there, you can expect 300,000 miles from that car
Link To Volvo Glossary
CaptainWeenieWagon
Year and Model: 2004 V70
Has thanked: 2 times
CaptainWeenieWagon
Post by CaptainWeenieWagon » Sun Mar 08, 2020 6:14 pm
What kind of upgrades can I do instead of just replacing?
Any sites I may need to familiarize myself with?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 41 times
Been thanked: 137 times
bmdubya1198
Re: What do you think?  Topic is solved
Post by bmdubya1198 » Sun Mar 08, 2020 6:52 pm
FCPeuro.com! Forum sponsor (at least I'm pretty sure they still are) and they have the best customer service out there. Price and selection are both great as well.
These users thanked the author bmdubya1198 for the post:
CaptainWeenieWagon
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2000 S70 GLT Mystic Silver/Taupe 253k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1993 944 Base Beige/Beige 221k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Trinidad & Tobago
Post by abscate » Sun Mar 08, 2020 7:11 pm
This is a high end car with high quality parts
Most of the “ upgrades” are inferior parts compared to OEM
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 18 times
Been thanked: 45 times
Georgeandkira
Post by Georgeandkira » Fri Mar 13, 2020 2:00 pm
Some will say "Volvo brakes only". Others go with lower dust options as an "upgrade".
I say Bilstein shocks and struts are an upgrade.
Many praise the thicker sway bars sold by IPD.
Many go zonkers over audio options.
There's plenty to do before you optimize your new ride.
You must visually inspect both rear parking brake hardware sets (left & right).
Also perform a glove test on the oil filler neck. This relates to the PCV system
You should do at least one transmission drain and fill (automatic, no?) to see & smell how foul the fluid is. If you've heard that our trannie fluid is "lifetime", you must have that section of your brain removed.
The coolant may be due for a refresh due to age or contamination.
Any service records? You likely need to replace the timing belt. You may be overdue for a complete "Stage 0" tune up.
The cabin air filter in any car can be overlooked.
A brake fluid flush and pin lube might be in order.
Check the spare for air and make sure the jack and wrench are there.
Year and Model: 2001 V70
Has thanked: 13 times
Been thanked: 40 times
Post by volvolugnut » Fri Mar 13, 2020 2:07 pm
Check the battery age and battery cable condition. These cars must have top condition battery to function properly. Confirm the charging system is strong. Obtain a code reader for Volvo or the full Vida Dice setup.
These users thanked the author volvolugnut for the post:
Georgeandkira
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
CaptainWeenieWagon
CaptainWeenieWagon
Post by CaptainWeenieWagon » Sat Mar 14, 2020 4:15 pm
So I need to replace a broken shifter in this automatic 04 V70 and I was wondering if anyone knows of any other options that fit? I can get an original for $32 on eBay. Just wanted something different. I have a spare lone shifting rod that I purchased to use a shifter I already had but no dice. Doesn't fit. Thank you for your time!
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Sat Mar 14, 2020 7:21 pm
The stock one is probably your best bet.
Trinidad & Tobago
Post by abscate » Sun Mar 15, 2020 6:29 am
Grab one from a junkyard, wonder how it broke?
