Did you know? 🤔
Fuel filter - best way to relieve pressure?
2001 - 2007 XC-70
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 36 times
United States of America
StickyPocket
Post by StickyPocket » Sun Mar 08, 2020 9:17 pm
2004 S60, gonna back it up on ramps and replace the fuel filter with a Hengst from FCP. Best way to relieve fuel pressure? Pull the relay while the engine is running?
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 6 times
Been thanked: 11 times
chris11211
Re: Fuel filter - best way to relieve pressure?
Post by chris11211 » Sun Mar 08, 2020 10:54 pm
There's a schrader valve to the left or near the tank. Unscrew the dust shield, push the pin with something like a tire pressure pen and a rag, then things should be easier.
Also, get a pan below the filter, there will be quite a spill.
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 286 times
Canada
oragex
Post by oragex » Mon Mar 09, 2020 4:19 am
COLD engine. If you do this on a warm engine, the warm fuel will keep 'expanding' and 10 seconds after releasing the pressure at the valve, when you'll pull the sensor out you will get a nice spray - warmly recommend using safety googles. When pushing on the valve, cover it with a piece of paper tower to soak the fuel and not get sprayed . Careful with the sensor screw not to strip the head, the sensor needs twisted while pulling gently and by all means use a little bit of vaseline on the o-ring of the new sensor
On a cold engine, the fuel pressure stays for weeks or months, so always release the pressure, even on a junkyard car.
Has thanked: 355 times
Been thanked: 1087 times
Trinidad & Tobago
Post by abscate » Mon Mar 09, 2020 4:35 am
You also still need to clamp off the upstream fuel hose on the filter
Link To Volvo Glossary
StickyPocket
StickyPocket
Post by StickyPocket » Mon Mar 09, 2020 6:39 am
What sensor screw are you talking about? I wasn't planning on replacing a sensor. Also, am i just opening the shraeder valve? (Where exactly is it?) Am i also pulling the pump relay? I'm reading multiple how-tos and they all seem to have different ways of releasing pressure, and some of them dont at all.
Thanks!
oragex
Canada
oragex
Post by oragex » Mon Mar 09, 2020 8:54 am
Oh, I presumed you are replacing the FPS sensor.. my mistake. No need for fuel pump relay, just undo the small cap of the valve at the rail, cover with a piece of paper towel - it will protect you and also suck in all the fuel, and depress with something the small pin on the valve. The gas is very hard to clean off hands, and also very smelly - would only do this outside
And this is what happens when working on a warm engine - I had released the valve pressure shortly before this, but since the engine was warm, the gas kept expanding and building pressure - so always work on a cold engine
chris11211
chris11211
Post by chris11211 » Mon Mar 09, 2020 10:10 am
Thanks!
The valves are, for example, what are on the wheels when you need to put in air into the tires. The part that sticks out and you have to push a pin in to let air in/out. It's the same idea for the gas line. So if you want to release pressure before releasing the fuel filter, then there is a valve between the gas tank and the filter.
chris11211
chris11211
Post by chris11211 » Mon Mar 09, 2020 10:11 am
Thanks!
That's just how i did it, no need to open the hood, or go anywhere else.
StickyPocket
StickyPocket
Post by StickyPocket » Wed Mar 11, 2020 10:59 am
Replaced it today. Pushed on the Shraeder valve and only a bit of gas dribbled out. Most of the spilling came from the open lines and old filter - but no pressurized spraying.
oragex
Canada
oragex
Post by oragex » Wed Mar 11, 2020 11:17 am
There should have been some pressure and hissing sound at the valve, I believe when the small stem is depressed. Will leak only little gas indeed, but must have some pressure to it
