I'll be performing maintenance on the server March 31. I'll try my best to make interruptions as painless as possible. Thanks for your understanding.
Did you know? 🤔
04 XC70 Spark Plugs Torque?
2001 - 2007 XC-70
hajjat
Year and Model: 04 Volvo XC70
Has thanked: 0
United States of America
hajjat
Post by hajjat » Sun Mar 08, 2020 11:38 pm
Hi, I'm changing the spark plugs on my 04 XC70 2.5T.
Does anyone know the torque specs?
RickHaleParker
Has thanked: 3 times
Been thanked: 479 times
RickHaleParker
Re: 04 XC70 Spark Plugs Torque?
Post by RickHaleParker » Sun Mar 08, 2020 11:46 pm
Hold ratchet extension with one hand. With the other hand put the finger tips on the end of the ratchet and pull with your fingers, not your arm muscles, until you feel the Crush Washer crush, stop.
The Crush Washer is right above the threads on the plug. Crush Washers are metal seals.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 6 times
Been thanked: 11 times
chris11211
Post by chris11211 » Sun Mar 08, 2020 11:54 pm
It's in the manual
Should be the same but for volvo s60 it's
Spark plugs
P/N272313-8 or equivalent
- Gap 0.028- 0.032 in. 0.7-0.8 mm
- Tightening torque 22 ft. lbs. (30 Nm)
- Firing order 1-2-4-5-3
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Post by oragex » Mon Mar 09, 2020 4:08 am
Engine cold - important both when removing and when installing new plugs. If I remember well, these have standard crush washers. First, I would screw in and out an old plug a few times, to make sure the threads are clean and it moves easily all the way down - may also use a little antiseize but only on the threads, not on the washer. As for tightening down, these normally require screwing in until the washer touches the bottom, then another 1/2 turn (in fact, I think to remember reading on the package about 3/4 turn). Personally I'm a bit scared to turn 3/4 so I leave it at 1/2 and I think it's enough. Because crushing that washer doesn't take force, that 1/2 turn will not feel hard to turn, rather light. Now, tightening down the same plug a second time it's different as the washer is already crushed - for that I would use a torque. But the first time it's just 1/2 turn to crush the washer. I recommend also getting a spare ignition coil inside the trunk - these can fail all of a sudden and it's better not to drive the car and replace it on the spot - will also need a 10mm wrench and the torx for the cover. I have a video showing how to find the bad coil
hajjat
Has thanked: 0
hajjat
Post by hajjat » Mon Mar 09, 2020 9:56 am
Thanks a lot, these are very useful tips as this will be my first time EVER changing spark plugs by myself!
Has thanked: 285 times
Been thanked: 898 times
Trinidad & Tobago
Post by abscate » Mon Mar 09, 2020 11:00 am
Nice!
Give us a yell when you are doing the deed if you need help
Link To Volvo Glossary
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 36 times
Been thanked: 0
StickyPocket
Post by StickyPocket » Mon Mar 09, 2020 2:58 pm
Check out the thread I started last year. I was in your same shoes - first time ever doing spark plugs. A lot of great help from this forum. A great feeling when it's done!
viewtopic.php?f=9&t=89034
