Did you know? 🤔
02 V70 XC Junk yard door - window, mirror, locks not working
2001 - 2007 XC-70
fastgroceries
Year and Model: 1996 Platinum 850
Has thanked: 8 times
Been thanked: 0
United States of America
fastgroceries
Post by fastgroceries » Tue Mar 10, 2020 4:55 pm
I replaced a dented front (right) passenger door with one from the same era (04 I think).
After mounting the door and reconnecting the wiring, none of the electronics but the speakers work. Door will lock from the fob, but not from the master switch.
Wifey was complaining about intermittent troubles in the driver window switch so I disassembled that switch and cleaned the rubber pressure pad and circuit board (with contact lens solution and an cotton ball). Reassembled that door and it's windows and mirror now work perfectly, but still no response from the passenger door.
I have tried both the original (02 grey) switch and the replacement (04 tan) switch and still no joy.
Tried disconnecting both door switches, disconnect the battery. reconnect the switches, then reconnect the battery. Nope...
I was able to make the window go up and down with 12v @ 6 A from a battery charger like Ozark Lee had written before. So, the motor works. The mirror is from the original car, so I know it's ok electrically.
Whaddya guys think?
'96 Platinum 850 #1 - was restored, but pretty beat up (long story)
'96 Platinum 850 #2 - mostly restored, mostly original, mostly a money pit
'02 XC-70 - Mom's indestructible vagen
'12 Nissan Frontier Pro4X - For hauling Volvo parts
sprocket007
Year and Model: 2001 V70XC
Has thanked: 0
Canada
sprocket007
Re: 02 V70 XC Junk yard door - window, mirror, locks not working
Post by sprocket007 » Wed Mar 11, 2020 1:57 am
normally i'd say from my experience to use the original switch if it worked and you should be ok...
Sounds like you tried that.
perhaps someone else can share their experience, I know this stuff drives me bonkers too !
Wade
These users thanked the author sprocket007 for the post:
fastgroceries
Has thanked: 289 times
Been thanked: 905 times
Trinidad & Tobago
Post by abscate » Wed Mar 11, 2020 3:39 am
Check that you haven’t crossed a CANBUS change in the P2 line.
Switches don’t control current anymore in P2s, they send signals to controllers to request action.
These users thanked the author abscate for the post:
fastgroceries
Link To Volvo Glossary
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 242 times
Canada
oragex
Post by oragex » Wed Mar 11, 2020 8:03 am
Was your original pass door working properly before the swap ?
fastgroceries
Been thanked: 0
fastgroceries
Post by fastgroceries » Wed Mar 11, 2020 3:37 pm
Yes electrically, the old door was functioning correctly.
What I will be trying next is to move the wiring harness from the old door over to the new one.
Cheers,
-Bud
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 22 times
chrism
Post by chrism » Wed Mar 11, 2020 4:21 pm
Did you check the fuse for that door?
fastgroceries
Been thanked: 0
fastgroceries
Post by fastgroceries » Wed Mar 11, 2020 10:18 pm
fuses ok
darrylrobert
Year and Model: 2001 v70xc
Has thanked: 2 times
Australia
darrylrobert
Post by darrylrobert » Thu Mar 12, 2020 5:40 am
when you swapped out the all electronic canbus switches with your original switches, check the wires are the same sometimes they make small changes.
These users thanked the author darrylrobert for the post:
fastgroceries
fastgroceries
Been thanked: 0
fastgroceries
Post by fastgroceries » Thu Mar 12, 2020 7:46 am
can you guys expand the CANBUS acronym? Not sure exactly wht that means but I think I can define it through context...
Anyhow, do you mean the wires color/pin position are the same in the harness from the old and new door?
Yes I'll check that later today.
Another question: Do you think the door lock mechanism (in the passenger door) would be coded to only work with my car? If so I may need to swap that over as well. PITA because it's riveted....
Trinidad & Tobago
Post by abscate » Thu Mar 12, 2020 8:16 am
CANBUS - its the era of computer control of stuff vs the old school method of wiring supply voltages to things.
On a 1998 car, when you push a window switch, it send current throught the switch to the electric motor in the door.
On a 2005 car, a different switch sends a signal to a controller that sends the current to the electric motor on the door.
The protocol and speeds of the BUS (the communication link) have to match and speak the same language - I think the 2002 and 2004 are the same but verify or else its resistance will be futile. If you grabbed a 2005 car door , the CANBUS speed changed that year so it won't work.
If you are lucky me and have a 1999/2000- CANBUS controls critical engine functions, and the rest of the car is analog!
fastgroceries
